simplyputsi 0 #1 March 10, 2008 How in the world was this texture created on drywall? This is a picture of my ceiling. I've stared at it for the longest time trying to figure out what technique was used and come up blank. I'm not just curious. I had to replace a section of the ceiling and want to try and match this texture the best I can so that it is not blatantly obvious a section was replaced.Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
jimmytavino 16 #2 March 10, 2008 it looks like drywall joint compound... applied with a very " large nap" paint roller... a bit of water is added to the 'mud' and then it is all mixed thoroughly , using a drill and a mixing paddle/bit, made for that purpose...in a pinch, it can be done with a large mixing stick and some elbow grease.... a paint roller with a long broom handle extension allows you to reach the ceiling, or wall, easily. load the roller heavily, sometimes the mixture is poured right into a paint pan... and then lay it on the surface... use just enough pressure to allow the roller to "roll" instead of slide.....it might take a time or two to get the hang of it. it can be messy, dripping, etc so use drop cloths, and mask any areas you want to remain undisturbed... It will dry very white... it can be painted, just like regular drywall , after it has fully dried...or left as is... good luck. jmy Quote Share this post Link to post Share on other sites
futuredivot 0 #3 March 10, 2008 This reminds me of Bib Villa's take on strip clubs vs. hookers "If you're going to spend just as much money doing it yourself, you might as well hire a profesional" I think that's what he was talking about You are only as strong as the prey you devour Quote Share this post Link to post Share on other sites
simplyputsi 0 #4 March 10, 2008 Two contractors said it can't be matched. I say whatever!! Somehow it was done. I don't know that I agree it was done with a paint roller. I do have some drywall that I can practice on so... The reason I just don't think it was a paint roller is because of the contractors telling me they can't match it. I'm not saying I won't give it a shot though.Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
PhreeZone 20 #5 March 10, 2008 They won't be able to match it exactly. Drywall compound dries many different shades of white and with out an exact match they patch will stick out like a sore thumb. I just did some ceiling repairs and needed to repaint the whole room's ceiling to get the coloring to match again. Futher getting the texture to look the same is a really hard thing to do.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
simplyputsi 0 #6 March 10, 2008 I'm already going to paint the entire ceiling in that room. Not that big of a problem as it's a small room. It's just the texture. I have no idea now to even get close to duplicating it. I've done small work on other parts where I can manage to make it blend but the area I'm patching is about 2 feet by 2 feet. Either way, it'll look better than it was before, and maybe when everything is painted up it will blend better.Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
turtlespeed 226 #7 March 10, 2008 QuoteI'm already going to paint the entire ceiling in that room. Not that big of a problem as it's a small room. It's just the texture. I have no idea now to even get close to duplicating it. I've done small work on other parts where I can manage to make it blend but the area I'm patching is about 2 feet by 2 feet. Either way, it'll look better than it was before, and maybe when everything is painted up it will blend better. You will probably have better luck matching the texture using a towel instead of a roller. The contractors are just covering their ass. It is unfortunate that they have to do this. They don't want to get into a situation where it will not look like a seamless repair. You will always be able to see the patch - usually though, only when you know it is there.I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
simplyputsi 0 #8 March 10, 2008 QuoteYou will probably have better luck matching the texture using a towel instead of a roller. Are you saying apply with towel, or apply the mudd and then use a towel to try and match pattern?Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
turtlespeed 226 #9 March 10, 2008 QuoteQuoteYou will probably have better luck matching the texture using a towel instead of a roller. Are you saying apply with towel, or apply the mudd and then use a towel to try and match pattern? It will PROBABLY be easier and cleaner to apply with a brush then use a wet towel to shape the texture to match. How big an area are we talking here?I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
futuredivot 0 #10 March 10, 2008 Quote The contractors are just covering their ass. Good, because most of the contractors that I know just show their assYou are only as strong as the prey you devour Quote Share this post Link to post Share on other sites
chaoskitty 0 #11 March 10, 2008 hmmm.. now I know how you guys feel when we talk about boobs. Quote Share this post Link to post Share on other sites
turtlespeed 226 #12 March 10, 2008 Quote hmmm.. now I know how you guys feel when we talk about boobs. Could you post an example please? I'm not 100% certain what you are referring to.Should I put my toolbelt on first?I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
chaoskitty 0 #13 March 10, 2008 Yes, put your toolbelt on and I'll post a photo of the spot in my living room ceiling that needs to be replaced. And then I've got those stupid popped ceiling textures that have got to go. But you guys are hot when youre talking about fixing stuff.. so carry on. Quote Share this post Link to post Share on other sites
DangerRoo 0 #14 March 10, 2008 Quote Yes, put your toolbelt on and I'll post a photo of the spot in my living room ceiling that needs to be replaced. And then I've got those stupid popped ceiling textures that have got to go. But you guys are hot when youre talking about fixing stuff.. so carry on. girl, you rock!! (I.C.D#2 VP) ""I'm good with my purple penis straw" ~sky mama Quote Share this post Link to post Share on other sites
simplyputsi 0 #15 March 10, 2008 Quote Quote Quote You will probably have better luck matching the texture using a towel instead of a roller. Are you saying apply with towel, or apply the mudd and then use a towel to try and match pattern? It will PROBABLY be easier and cleaner to apply with a brush then use a wet towel to shape the texture to match. How big an area are we talking here? Errr negative on the brush application. I use a putty knife, a larger one. I am thinking that the towel method might work though. I read something that newspaper can be used to make a texture and that got me thinking that I might need to use something like that. and ummm read up turtle, 2x2. geeshSkymama's #2 stalker - Quote Share this post Link to post Share on other sites
simplyputsi 0 #16 March 10, 2008 Just to let you and kitty know I have many projects to complete in my place. Anytime you want to come watch and lend "a hand" just let me know Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
chaoskitty 0 #17 March 10, 2008 Quote Just to let you and kitty know I have many projects to complete in my place. Anytime you want to come watch and lend "a hand" just let me know But its a lot hotter if you're fixing stuff at *my* house.. Quote Share this post Link to post Share on other sites
sunshine 2 #18 March 10, 2008 Quote Good, because most of the contractors that I know just show their ass But in the case of my bf...that's a good thing. He's hot. ___________________________________________ meow I get a Mike hug! I get a Mike hug! Quote Share this post Link to post Share on other sites
simplyputsi 0 #19 March 10, 2008 Quote Quote Just to let you and kitty know I have many projects to complete in my place. Anytime you want to come watch and lend "a hand" just let me know But its a lot hotter if you're fixing stuff at *my* house.. So you want me to come work on you at your house?Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
chaoskitty 0 #20 March 10, 2008 Yah something like that.. Quote Share this post Link to post Share on other sites
turtlespeed 226 #21 March 10, 2008 Quote Errr negative on the brush application. I use a putty knife, a larger one. I am thinking that the towel method might work though. First off - you have to mix the Joint compound @ about 30/70 (Water/Joint Compound) A putty knife will not be able to apply the mixture efficiently. Second - if you want to save the hassle of getting a brush - use one of those shower things that thhe chicks like - loofas J calls them - I call them "Poofy bath things that chicks like." (Just dip and splat, and let set for a few minutes) Then - using a towel (preferably a baby blanket or something cotton and smooth - even a t-shirt will work - draw in the design of the texture and smooth out to match the existing. (Try different tools wrapped up by the cloth and you will be able to see what works in just a few minutes)I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
simplyputsi 0 #22 March 10, 2008 Admit it turtle you use a loofa.Skymama's #2 stalker - Quote Share this post Link to post Share on other sites
tkhayes 348 #23 March 10, 2008 it is done with a large fluffy paint roller and some mud loike the first poster said - and no - you will never be able to match it well - just like any stucco job. It will vary depending on the type of roller, the thickness of the fluff, the type of mud, consistency of the mud, etc. Best thing is to re-stucco the whole ceiling with a new and improved stucco like popcorn or something fairly fine, that will cover what is already there.- whatever, equally a pain in the ass and just as ugly. Stucco was invented to cover up lousy drywall jobs. Smooth walls are my preference and for ceilings too. A smooth ceiling with crown molding looks way better that any stucco job. good luck with it. Quote Share this post Link to post Share on other sites
caress 0 #24 March 10, 2008 In my 10 years building new homes, I have not ever seen that. Do you like it? It looks very interesting and from the looks of it I would say that it probly took a long time to do that. Like it was intentional art work. I think you may want to go with a complete redo if it is such a small area. It is your place. Wow that is definetly different.- I've learned.... That being kind is more important than being right. Quote Share this post Link to post Share on other sites
skydiver30960 0 #25 March 10, 2008 Quote Stucco was invented to cover up lousy drywall jobs. Smooth walls are my preference and for ceilings too. A smooth ceiling with crown molding looks way better that any stucco job. . This is kinda what I was thinking. The reason the guy with 10 years' experience has never done this is just that: it hasn't been in style for that long. Although it'd suck to have to do the extra work, refinishing the whole deal will add to the value of your home when you sell. Elvisio "what I've learned from hours and hours of do-it-yourself shows" Rodriguez Quote Share this post Link to post Share on other sites
