			It wont rip you up at all - regardless of the reserve pilot chute size (right up to a fully inflated main canopy) the dbag may well left off quicker, linestretch may occur quicker, the canopy may leave the dbag quicker, but the reserve canopy wont *inflate* any quicker - thats dependant on the slider and packjob.
Pretty much the only thing that will happen using the departing main (partially inflated for example) will be the freebag will come off the reserve canopy quicker than with a regular sized pilotchute. Theres absolutely nothing wrong with that.
Remember the super-pilotchute isn't 'attached' to the reserve canopy in the same way as the dbag is attached to the main canopy. It might cause a problem (centre cell stripping) if it were, but its not.
	billbooth 10
			We've been doing quite a lot of testing with direct bag static line ram air systems for the military lately...many of these tests are done at over 120 mph. In this case, the "super pilot chute" is the aircraft, which I will guarantee you pulls a lot harder than any main parachute could. While opening shocks are often a bit harder than a normal terminal freefall deployment (due mainly to the angle at which the relative wind first hits the canopy), we are not killing people or tearing up canopies.
			Thanks for that Bill - as usual, you're over engineering everything!
		Quotebut the reserve canopy wont *inflate* any quicker - thats dependant on the slider and packjob.
The opening time of a canopy is dependent on the size and design of the slider and the fill time of the canopy. Fill time can be altered by packing but not much. It is mainly dependent on size and design.
Sparky
		skydiverek 65
			The only "theoretical problem" I can come up with is "slider rebound" theory. What I mean by this is the situation where:
The jumper has a bag-lock. He cuts-away. The SAME moment the main inflates. The now "super pilotchute" pulls/decelleretes the freebag extremely fast. The line stretch is reached. The freebag slides off. At THAT time the reserve pack job is abruptly stopped by the now stretched lines (and accelerated back to the jumpers sped). This jerk discrupts the pack job and makes the slider bounce off the slider stops and travel some inches down the lines BEFORE the inflation. That causes the reserve to inflate faster.
End of scenario.
Any comments
End of scenario.
Any comments
			but your describing it like the main inflates instantly - it doesn't. as it comes out of the bag, its barely bigger than the slider, which in turn is bearly bigger than the pilotchute.
I just cant picture it being a problem.
DJL 235
Quote...slider rebound theory...Any comments ?
Yup. I saw a peanut stand, heard a rubber band, I saw a needle that winked its eye, I saw a front porch swing, heard a diamond ring...
"I encourage all awesome dangerous behavior." - Jeffro Fincher
Just my thoughts, I may be wrong.
