kansasskydiver 0 #1 June 18, 2008 Techies I need help: Server 2003 R2 SBS will be set up as dedicated quickbooks enterprise server. Full gigabit network with unmanaged switches. DHCP, gateway, dns all controlled on alternate server. Is there a way to set up the quickbooks server with nic01 as incoming traffic and nic02 as outgoing traffic or would it not even be worth the hassle? Our quickbooks file is around 1gig and take a huge chunk out of our current server's processor and networking capabilities. New server will be dual quad cores and I'd like to try and utilize the dual nics to control some of the traffic. Thanks in advance <--- See look, pink dolphins DO exist! Quote Share this post Link to post Share on other sites
Bolas 5 #2 June 18, 2008 Quote Techies I need help: Server 2003 R2 SBS will be set up as dedicated quickbooks enterprise server. Full gigabit network with unmanaged switches. DHCP, gateway, dns all controlled on alternate server. Is there a way to set up the quickbooks server with nic01 as incoming traffic and nic02 as outgoing traffic or would it not even be worth the hassle? Our quickbooks file is around 1gig and take a huge chunk out of our current server's processor and networking capabilities. New server will be dual quad cores and I'd like to try and utilize the dual nics to control some of the traffic. Thanks in advance As long as you are using full duplex gigabit switches and NICs you don't need to try to segment the traffic. If anything, just team the NICs for redundancy and speed. Having two IP's tied to the same name on the same network can be more trouble than it's worth. Stupidity if left untreated is self-correcting If ya can't be good, look good, if that fails, make 'em laugh. Quote Share this post Link to post Share on other sites
kansasskydiver 0 #3 June 18, 2008 Quote As long as you are using full duplex gigabit switches and NICs you don't need to try to segment the traffic. If anything, just team the NICs for redundancy and speed. Having two IP's tied to the same name on the same network can be more trouble than it's worth. Yep and yep on the switches and cards. How would I go about teaming them up for redundancy? I guess I can google it but any hints lol Thanks again Quote Share this post Link to post Share on other sites
Bolas 5 #4 June 18, 2008 Teaming is usually an option in the NIC configuration software. In Dell and HP servers it is usually on the taskbar as long as all the drivers and agents are installed.Stupidity if left untreated is self-correcting If ya can't be good, look good, if that fails, make 'em laugh. Quote Share this post Link to post Share on other sites
futuredivot 0 #5 June 18, 2008 Quote [As long as you are using full duplex gigabit switches and NICs you don't....blah blah blah blah Dude! How's that Starfleet uniform coming along You are only as strong as the prey you devour Quote Share this post Link to post Share on other sites
Bolas 5 #6 June 18, 2008 Quote Quote [As long as you are using full duplex gigabit switches and NICs you don't....blah blah blah blah Dude! How's that Starfleet uniform coming along How's that Windows XP SP3 recovery coming? Stupidity if left untreated is self-correcting If ya can't be good, look good, if that fails, make 'em laugh. Quote Share this post Link to post Share on other sites
futuredivot 0 #7 June 18, 2008 Quote Dude! How's that Starfleet uniform coming along How's that Windows XP SP3 recovery coming? I ain't got nothin for that oneYou are only as strong as the prey you devour Quote Share this post Link to post Share on other sites
normiss 897 #8 June 18, 2008 it's called Vista. Quote Share this post Link to post Share on other sites
