mattyblast 0 #1 January 16, 2006 *searches forums* *comes up empty* Hey folks. I need a primer on serial numbers. Where are all the places they're found on containers and canopies? We'll start with that--I'll probably have follow-up questions. Go easy on me, I'm a newbie."DOOR!!!" Quote Share this post Link to post Share on other sites
skybytch 273 #2 January 16, 2006 You can find the serial number on the data panel. Where the data panel is located depends on the item. Here are a few that I know off the top of my head... Canopies - generally located on the center cell at the tail. Containers - Javelin - on a flap under the top reserve flap; often tucked into the clear pocket where the packing data card is kept. Infinity - inside the right "mud flap" or "ring cover" Talon - sewn onto one of the reserve risers Quote Share this post Link to post Share on other sites
sid 1 #3 January 16, 2006 On a Racer the Date of Manufacture is the serial No. It's on the door covering the reserve pins, on all Jumpshack Canopies (Firebolt, Angelfire etc) it on the data panel sewn into the center cell rib.Pete Draper, Just because my life plan is written on the back of a Hooter's Napkin, it's still a life plan.... right? Quote Share this post Link to post Share on other sites
Spatula 0 #4 January 16, 2006 Mirage - inside of main pack tray Quote Share this post Link to post Share on other sites
GravityGirl 0 #5 January 16, 2006 Cypres, Reserve and Container on the Packing Data Card. ~~~~~~~~~~~~~~~~~ Peace and Blue Skies! Bonnie ==>Gravity Gear! Quote Share this post Link to post Share on other sites
Vectracide 0 #6 January 16, 2006 Hey Matty, You've been given all the good info. If you are needed them to check for stolen gear, there is a part of the site here that has that info. Good reference: http://dropzone.com/stolen/ Later. ------------------------------ Controlled and Deliberate..... Quote Share this post Link to post Share on other sites
Tink1717 2 #7 January 16, 2006 Wings: On flap inside rear of the left side of the harness.Skydivers don't knock on Death's door. They ring the bell and runaway... It really pisses him off. -The World Famous Tink. (I never heard of you either!!) AA #2069 ASA#33 POPS#8808 Swooo 1717 Quote Share this post Link to post Share on other sites
Reginald 0 #8 January 17, 2006 Quote*searches forums* *comes up empty* Hey folks. I need a primer on serial numbers. Where are all the places they're found on containers and canopies? We'll start with that--I'll probably have follow-up questions. Go easy on me, I'm a newbie. Based on a number of your posts it sounds like you are thinking about buying some used gear?"We've been looking for the enemy for some time now. We've finally found him. We're surrounded. That simplifies things." CP Quote Share this post Link to post Share on other sites
masterrig 1 #9 January 17, 2006 Racer serial numbers: first 2-digits: week. 2nd. two digits: year. Last digits: sequence. Chuck Quote Share this post Link to post Share on other sites
riggerrob 644 #10 January 17, 2006 Containers: default location is under the reserve pin cover. Second location is at the top of the back pad: Infinity, Sidewinder, Softie, etc. Similarly, Rigging Innovations products (Talon, Voodoo, Telesis, Aviator, etc.) have two data panels: center of back panel (folded in with packing data card pocket) and right reserve riser. Third location is on the inside of the shoulder pad, below and behind 3-Rings: newer Mirages, Vector, etc. An old method involves sewing labels to the lower, horizontal back strap, still seen on Strong tandem student harnesses. Quote Share this post Link to post Share on other sites
masterrig 1 #11 January 17, 2006 An old method involves sewing labels to the lower, horizontal back strap, still seen on Strong tandem student harnesses. ______________________________________ I remember that from the old 'Starlite' rigs. Chuck Quote Share this post Link to post Share on other sites
