PrairieDoug 0 #1 December 16, 2005 The thread in Incidents about the recent hard opening at Skydive Dallas got me thinking again about the wisdom of using dacron lines to protect against hard openings. Bill Booth had this to say: QuoteAgain, I ask the question: Is the small amount of extra speed you get from jumping with "no-stretch" lines worth all the injuries, and fatalities, we are getting from hard openings nowadays? So I was wondering how many jumpers use dacron vs. non-stretch lines. In my case, I ordered spectra without being aware of safety issues. Will probably switch to dacron for next line set. Quote Share this post Link to post Share on other sites
nitrochute 2 #2 December 16, 2005 "back in the day"(1968 or so) when steve snyder was working with the irvin deltaII, they tried steel cables ,ted strong i believe jumped it and promptly tore off some line attchment points(l.a.p.s) Quote Share this post Link to post Share on other sites
PrairieDoug 0 #3 December 16, 2005 Steel sounds crazy, but IIRC Bill Booth has said that steel actually absorbs shocks better than microline. Quote Share this post Link to post Share on other sites
rushmc 23 #4 December 16, 2005 My Sabre2 came with Spectra. Put 75 to 100 jumps on it, did some research, learned some details, cut the Spectra off and installed Dacron. Made a difference."America will never be destroyed from the outside, if we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln Quote Share this post Link to post Share on other sites
justinb138 0 #5 December 16, 2005 QuoteMy Sabre2 came with Spectra. Put 75 to 100 jumps on it, did some research, learned some details, cut the Spectra off and installed Dacron. Made a difference. Did you notice any different in glide/forward speed? Quote Share this post Link to post Share on other sites
rushmc 23 #6 December 16, 2005 QuoteQuoteMy Sabre2 came with Spectra. Put 75 to 100 jumps on it, did some research, learned some details, cut the Spectra off and installed Dacron. Made a difference. Did you notice any different in glide/forward speed? No, but I do not do HP landings and I have it loaded enough that I am really moving anyway."America will never be destroyed from the outside, if we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln Quote Share this post Link to post Share on other sites
sundevil777 102 #7 December 16, 2005 QuoteWill probably switch to dacron for next line set. Unfortunately pack volume is significantly larger also.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
thepollster 0 #8 December 16, 2005 Quote Unfortunately pack volume is significantly larger also. IMHO, in occurance of tension knots is higher (w/ dacron) as well. A q. for Bill Booth: If, as you claim, people used to get knocked out from hard openings, why do they now get injured instead of knocked out? It seems to me like openings in the old days were harder with dacron than we have now with no stretch lines. Quote Share this post Link to post Share on other sites
HydroGuy 0 #9 December 17, 2005 You should seperate Spectra and Vectran. Spectra might be no-stretch, but it isn't no-shrinkGet in - Get off - Get away....repeat as neccessary Quote Share this post Link to post Share on other sites
crazydiver 0 #10 December 17, 2005 Quote A q. for Bill Booth: If, as you claim, people used to get knocked out from hard openings, why do they now get injured instead of knocked out? It seems to me like openings in the old days were harder with dacron than we have now with no stretch lines. Better canopy design. Better opening trims. It's also easier to make a small canopy open slower/softer than a larger canopy. Cheers, Travis Quote Share this post Link to post Share on other sites
teason 0 #11 December 17, 2005 Spectra is no-stretch now? When did that happen? I know it stretches less than dacron but no-stretch? Are you sur you're not thinking of Kevlar line? Spectra's low stretch attributes are the reason the lines stay in trim longer. If the high stretch attributes are why you want dacron, then why not nylon line? They can stretch up to 20%! The fact is there are many things that can be done to reduce opening forces. Going to a line that is less robust and bulkier seems odd to me.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
crazydiver 0 #12 December 17, 2005 QuoteSpectra is no-stretch now? When did that happen? I know it stretches less than dacron but no-stretch? Are you sur you're not thinking of Kevlar line? Spectra's low stretch attributes are the reason the lines stay in trim longer. If the high stretch attributes are why you want dacron, then why not nylon line? They can stretch up to 20%! The fact is there are many things that can be done to reduce opening forces. Going to a line that is less robust and bulkier seems odd to me. Correct, spectra has more stretch than vectran/hma etc. But spectra goes out of trim almost as quickly as dacron, but dacron stretches permanently over time and spectra shrinks over time due to heat created by friction from the slider. Spectra IS nylon line. Dacron is polyester. Cheers, Travis Quote Share this post Link to post Share on other sites
masterrigger1 2 #13 December 17, 2005 Quote Correct, spectra has more stretch than vectran/hma etc. But spectra goes out of trim almost as quickly as dacron, but dacron stretches permanently over time and spectra shrinks over time due to heat created by friction from the slider. Spectra IS nylon line. Dacron is polyester. Mostly correct! The one part that is not correct is Spectra goes out of trim FASTER than Dacron. Dacron is also more consistent in regards to how much stretch vs number of jumps. With Spectra, you just never know when it is out of trim unless you measure the lines regularly. MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
billbooth 10 #14 December 17, 2005 I used to get "knocked out" quite often (but never "injured") jumping early ram airs without sliders. But they had NYLON lines which are very stretchy. I think the difference is the "speed of onset" of the opening force on the jumpers body. Think of falling on a bare wood gym floor. Then take the same fall with a 2" mat on the floor. The same force is applied, but the compression of the mat spreads it out a little, so the fall on the mat is less likely to injure you. Nylon, and to a lesser extent, Dacron lines work the same way to spread out the force a little. Because the force builds up more gradually, your body has more time to "get ready" for the peak, which is never as high anyway. Quote Share this post Link to post Share on other sites
jojo0815 0 #15 December 17, 2005 QuoteQuote With Spectra, you just never know when it is out of trim unless you measure the lines regularly. very true indeed. I for myself don't like spectra except for closing loops. but it all depends on what you expect from your canopy. if you want performance I like vectran the best. it isn'tas bridle as HMA and doesn't go out of trim like spectra. for wingsuits I prefer dacron because I like fast openings.... i don;t mind the extra pack volume there. if you keep having hard openings it might be worth to pay a good packer to show you some tricks as well Quote Share this post Link to post Share on other sites
teason 0 #16 December 17, 2005 QuoteSpectra IS nylon line. Buzzzzzzzzz. Incorect Cored nylon line predates spectra. It is mostly seen coreless and used as closing loops. Nylon line had a very high elongation propertyof about 20%. This made it an ideal line in the days of old. Spectra is an ultra high strength polyethylene fiber Polyethylene Fiber — (Spectra currently produced in the U.S. by Honeywell) is one of the world's strongest and lightest fibers. A bright white polyethylene, Polyethylene fiber is, pound-for-pound, 10 times stronger than steel and up to 40 percent stronger than aramids. It floats, resists chemicals and water, and exhibits superior fiber-to-fiber abrasion. Basically, nylon is a familly of synthetics not a specific material but when we talk about Nylon line in skydiving we are talking about type II or type V, not spectra. Spectra is Olefin.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
crazydiver 0 #17 December 17, 2005 I know what type II nylon line is. But saying nylon line is like saying my canopy is made of nylon. Of course it is. but what kind? Cheers, Travis Quote Share this post Link to post Share on other sites
teason 0 #18 December 18, 2005 I just had two real points; first in skydiving nylon line is usually type II or V. Secondly, Spectra is olefin not nylon. Now unless we have those in the textile field out there, the specific type of nylon will probably be useless. I know of about 75. There is a good chance that type II line is made from TypeII nylon!) All you need to know is this; 1.)Type II & V are a nylon 6/6 line which is a poly amide base with an elongation of about 20% 2.)Kevlar is an aramid with very low resistance to abrasion. It's also a bitch to fingertrap and has very low elongation. It also breaks down quickly in UV light 3.)Dacron is a polyester base with an elongation of about 12-16%. 4.)Vectran is a a liquid crystal aromatic polyester noted for its thermal and chemical stability, moisture resistance, and high strength and modulus. 5.) Spectra is an olefin polyethylene fibre with an elongation of about 5% if memory serves. It is 40% stronger than kevlar and 4 time stronger than nylon. In tests, nylon line fails after 550,000cycles Polyester fails after 150,000 cycles Kevlar after 25,000 cycles And the big winner (you guessed it) Spectra with 675,000 Cycles! And by the way, you can also make fabric out of Dacron, Nylon, Spectra and kevlar. Just a fun factI would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
masterrigger1 2 #19 December 18, 2005 Teason, Pure Cycles of the different fibers are not all that we are looking for in line material. Also, as you may already know, changing the fiber, carrier and bundle count changes the strength of each material In the case of Spectra,it may have lasted longer, but the desired length of it will have diminished well beyond the other fibers. So, In the parachute world it would not be the winner. You remind me of my friend who is a chemist. This is his exact field. MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites
mjosparky 4 #20 December 18, 2005 Quotefirst in skydiving nylon line is usually type II or V. When you say Type II & Type V, are you reffering to MIL-C-5040 Cord, Nylon, MIL-C-7515 (MIL-C-7981) Cord, Nylon Braided or MIL-C-17183 Cord, Nylon Braided, Tubular? SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
PhreeZone 20 #21 December 18, 2005 Dacron fabric is the fabric of choice in a lot of Ultralight planes. Its also in use on at least 1 Wingsuit design out there.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
teason 0 #22 December 18, 2005 QuoteYou remind me of my friend who is a chemist. This is his exact field. Excactly. It's kind of absurd to go beyond the basic definitions of the different types of line. After a while it just becomes noise. My real point was that Spectra isn't nylon and the lines all have different make up and properties. Strengths an weaknesses, if you will. I was replying to a "stump the wizard" question about the "type of nylon" in nylon line. Just trying to post a point.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
teason 0 #23 December 18, 2005 I think you know what I mean. But just for the sake of answering the question, I Actually mean MIL-C-5040 type IIa (or just core Type, same thing) It is most commonly used for closing loops. I've also seen Type II used on handgliding reserves quite extensively (as well as spectra). Many other canopies used nylon line ranging from type I in pilot chutes, Type III on military mains, Type IV in early para foils and Type V in early paraplanes. Generally, "nylon line" cover all these types as well as the Mil specs you have mentioned. Type IIa and V seem to be main ones I see, type V also being used in closing loops on Racers. By the way when you say Dacron, do you mean flat braided......?I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
vt1977 0 #24 December 19, 2005 I had my Spectre relined with dacron about a year ago because the microlines I had had previously had shrunk so much that the brake lines were 8 inches too short and the canopy was no longer flaring adequately. The dacron lines have improved the openings with only a very small increase in pack volume (hardly noticeable). The dacron lines were cheaper than microline too! It's an absolute no-brainer in my opinion! Vicki Quote Share this post Link to post Share on other sites
mjosparky 4 #25 December 19, 2005 QuoteBy the way when you say Dacron, do you mean flat braided......? As far as I know, Dacron only comes in braided, coated or uncoated. I have never seen it in a true "flat braid". SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
