Wear a 8" Cabar and strech your arms out the next time you pack it. Make sure that your canopy sees your serious knife. Then get down and say just load enough for just your canopy to hear, you don't want to embarres her, " Listen you snivily ol' rag if you don't get with the program real soon I'm going to cut you up into strips roll and sell them as trendy toilet wipe and use your lines for boot laces that I'll give to the salvation army.
Now I don't know if this will work for you but if you go that far at least she will know your very serious bout opening with some degree of urgency.
teason 0
QuoteThe snatch force is a characteristic of the canopy, not the line stows.
Not with line stoes? I'll call shananagins on that. Total absolute and complete shananigans
Here's the definition.
"Snatch force-The shock produced on the load when the parachute assembly fully strings out and becomes suddenly accelerated to the same speed as the load. Comes prior to opening shock."
The canopy is just a one part of the equation. A large part of what determines snatch is the speed of the assembly prior to excelleration. Clearly tight elastics will slow the decelleration prior to line stretch.
Here's the equation: snatch force=delta speed/time.
There are two ways to reduce snatch.
1. decrease the delta speed
2. increase the time
Decreasing the delta speed is achieved by slowing the bag's decelleration off the back.
Increasing the time is achieved through various means (packing, canopy design)
I believe you may have confused snatch force with opening shock. That is very dependent on the canopy and is the second part of the process.
I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet.
Than why do the openings feel the same with or without linestows?
Johnny
--"This ain't no book club, we're all gonna die!"
Mike Rome
Johnny
Mike Rome
teason 0
The reason to inspect your selvage edges is that an uneven deployment can result is an 80-20 load on your harness. a damaged selvage edge weakens the webbing.
Although main deployments are usally orderly, a reserve deployment is not always. (for example a streamer can put you is a wacky body position with providing decelleration.)
If you have student gear, this can become even more critical.
As long as the lines are deployed evenly, the canopy should open the same. You can do this via rubberbands, line pocket or coil of death. I like packing the coil of death for people while they are looking on in horror!!!
Johnny
Mike Rome
