millertime24
Xbox360 problems any ideas?
For some reason my 360 is having issues with its outputs. The only way I can really rely on it now is to use the HDMI output. Whats happening is if I'm using the components, sometimes the screen will just go completely blank and say "no signal" then when I hook up the HDMI it seems as if the 360 has reset itself, but I never lose the actual headset sound during the whole time. Weird. Has anyone else had this type of issue and if so what did you have to do to fix it?
Muff #5048
At least I'm actually lucky there. Ive only had the damn thing for about 1.5 weeks so if the fucking thing catches on fire I can still take it back to Best Buy and get another one. Also since it works with the HDMI cable I think Ill just run that instead of messing with the components and Ill just have to put up with running components from my HD cable reciever to my tv until I can afford another HDMI cable. Still, really wished the entire system worked as it was designed.[:/]
Muff #5048
