turtlespeed
Does Dry Ice . . .
. . . melt or vaporize?
Logically it seems that the liquid form would exist, if even for a minute instant.
I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama
BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun
I vote for vaporize! ;)
Dry Ice is frozen carbon dioxide. Unlike most solids, it does not melt into a liquid, but instead changes directly into a gas. This process is called sublimation. The temperature of dry ice is around -109° F! It melts very quickly so if you need dry ice for an experiment or project, buy it as close as possible to the time you need it.
But I guess it all depends on your definition of "melt."
Nina
Are we called "DAWGs" because we stick our noses up people's butts? (RIP Buzz)
Yep, you're a postwhore-billyvance
It vaporizes. (The scientific term is sublimate, or go directly from solid to gas.) Ice can also sublimate, which is why ice cubes slowly disappear in your freezer. Its converse is deposition, where something goes directly from a gas to a solid (as in frost.)
Nope. That's why ice can sublimate at below freezing temps.
Apparently ...
Carbon dioxide has no liquid state at pressures below 5.1 atm.
Is that because it goes from solid to vapor instantly, or if you could slow time down to view the process, would you see a liquid state for milliseconds. I think that they are saying that there is no sustained liquid state below 5.1 atm.
Hmmm . . . counter intuitive, but I'll accept that answer.
I can tell you that dry ice explodes...
I don't recommend trying it. I found out by accident. We had to have part of the front porch replaced...
If you can't laugh at yourself, I'll be happy to do it for you.
Be like the cupcake and suck it up.
I think if I told you the specifics of what we did I could get busted for telling you how to make a bomb.
Again - it was a complete accident. We had no idea we were going to blow things up. It was on Halloween night and thankfully there were no children on the porch when it happened.
Something tells me there was a closed container of some kind that was involved.:)
Where do you think the fog on top of the frozen pond comes from
Divot your source for all things Hillbilly.
Anvil Brother 84
SCR 14192
I am guessing the same thing that causes fog over a pond that is not frozen. Temperature, humidity and air pressure.
