"Tapered" vs "Semi-Elliptical" vs "Fully-Elliptical" vs "Cross-braced"
					By
Elisha,   in Gear and Rigging
teason 0
QuoteNo canopy is truly "fully elliptical."
The Firebolt is a true eliptical. I believe it's based on a truncated 3:1 elipse.
Elisha 1
So, do I assume correctly that at least industry speak, "tapered" = "semi-elliptical" (e.g. Sabre2, Pilot, Safire2) and "fully elliptical" would be a Stiletto/Katana/Mamba/Crossfire 2?
rmsmith 1
QuoteI have a math degree...
Then you know the difference between surface area v. the area of projection, right?
Elisha 1
		rmsmith 1
Quote...but I'm not a Topologist.
Use some judgement in your canopy choice, and take the time to see what the old-timers fly. They are still active in the sport many years later because they made wise gear decisions.
/* BTW, do you SAS at your job? */
QuoteI have a math degree, so I was rather sure that at least a or most "Fully-Elliptical" canopies really were not.
Yes, I think the general perception is that the semi-elliptical canopies are the "well behaved" tapered canopies while the fully elliptical canopies are the nylon version of a fighter jet.
IIRC, at least the Safire2 is marketed as fully elliptical. I can't be sure at the moment about the Sabre2 or the Pilot.
Take the terminology with a grain of salt.
For Great Deals on Gear
Elisha 1
QuoteQuoteI have a math degree, so I was rather sure that at least a or most "Fully-Elliptical" canopies really were not.
I'm just trying to figure out what the terminology is supposed to mean. Are you sure you don't mean the Crossfire2? I wouldn't think the Safire2 would be considered in the same class as the Pilot or Sabre2 if it is indeed considered fully elliptical.
Term like "Elliptical","Semi-Elliptical" vs "Fully-Elliptical"
are Marketing Mambo-Jambo.
Does "multimedia" or "hybrid composite (material)" make any sense?
jakee 1,649
QuoteI'm just trying to figure out what the terminology is supposed to mean. Are you sure you don't mean the Crossfire2? I wouldn't think the Safire2 would be considered in the same class as the Pilot or Sabre2 if it is indeed considered fully elliptical.
It's just another example of marketing speak, I'm pretty sure that Icarus uses the phrase 'truely elliptical' to describe not only the Safire2 but also their Spectre equivalent 7-cell canopy.
Truely elliptical and lightly elliptical at the same time.
True. It would not be easy. And probably not fast. But it would be appreciated, and helpful when trying to get out good information. I had to ask.
You don't believe the other manufacturers have not already purchased your gear to test, measure and otherwise scrutinize, do you? They already know your secrets.
