skybytch 273
QuoteAtair recommends to choose a canopy that is 2 sizes smaller than what you want for performance also so the 135 is 2 sizes smaller than a 170.
Don't believe the Atair hype. A 135 is a 135 is a 135.
Good luck.
jsaxton 0
QuoteQuoteyou might want to have them replaced with something more "dimensionally stable" like vectran or dacron for the lower control lines.
Not Vectran. While it doesn't shrink like Spectra, it doesn't show wear like Spectra or Dacron. Being able to see wear on your control lines is a good thing; having a lower control line break on final would really suck.
Yeah, ask Peter (titanium legs) Learmouth![]()
QuoteNot Vectran. While it doesn't shrink like Spectra, it doesn't show wear like Spectra or Dacron. Being able to see wear on your control lines is a good thing;
Vectran shows wear just fine. HMA on the other hand doesn't.
Remember, Velocities are still lined with Vectran (including brakes). I do agree that it does require more maintenance than dacron or spectre from a breakage point of view though.
Blues,
Ian
RMURRAY 1
QuoteQuoteNot Vectran. While it doesn't shrink like Spectra, it doesn't show wear like Spectra or Dacron. Being able to see wear on your control lines is a good thing;
Blues,
Ian
I just keep records of exactly how many jumps on my canopy. Most people know that at as low as 300 spectra could be out of trim. Vectran lower control lines need to be watched constantly.
I have cascaded HMA now (dacron lower control lines) I expect 800 from them but we will see....
rm
dbattman 0
I bought a Vectran lineset from Skyworks Parachutes in Buffalo, South Carolina. The lower control lines on this set are not Vectran (which is good). Atair will sell but not install linesets. When you do your lines try to get the steering lines so the stall point is about full extension plus a shoulder roll down.
And yes, I agree with the others- you are putting yourself in the red zone. Aerodyne makes a great canopy for your level called the Pilot.
TaylorC 0
QuoteQuoteAtair recommends to choose a canopy that is 2 sizes smaller than what you want for performance also so the 135 is 2 sizes smaller than a 170.
That mother fucker has got no soul![]()
Lengthen your brake lines. Anybody without enough experience to figure that out by himself shouldn't be jumping anything that highly loaded.
Canuck
Sorry if the paragraphs are out of order since i just edited it and i don't wanna proofread my whole post again
I didn't come here to start this whole conversation about jumps numbers and what is a good size canopy for that level. I just wanted to reassure what i already thought and was told the problem might be. Since i read something that said if it bucks i might just be pulling the front riser down to far but i knew i wasn't doing that since i only pulled it down 3 inches and it started bucking. I like to make sure i am 100% correct before i go and buy new lines for it.
As i said in my first post i thought it might be something with lines but i wasn't 100% sure cause maybe it might have been something else. Everyone who sees me fly canopy is suprised at how well i do considering my jump numbers. I did not buy this canopy from atair and i have no problems flying a 135 i don't hook it in i don't do anything extreme with it. I found my 170 to be a bit slow after i lost that 10 pounds and needed something new. I do understand you guys are trying to look out for me and i appreciate it but i needed something faster and i did transition on a 150 stilleto for a few jumps before i went to the 135 + i had 10 jumps on 135's before i got this one, I know it isn't much. i have been opening really high and learning to fly my canopy. If it wasn't so damn cold i woulda been doing 10000 foot hop and pops all weekend with it.
dbattman 0
It's not the hooking or extremes that are going to do you in. It's the other low timer that cuts you off, the strong gust at 50 feet, the 'oh shit' turn or the foiled crosswind landing that causes you to reach your hand out to brake your fall (holding your toggle and causing you to turn yourself into the ground).
We've seen many more come before you that said the same thing. Have fun and try not to hurt yourself, or worse hurt someone else.
TaylorC 0
dbattman 0
If you look at our fatality numbers the danger zone is between 300-800 jumps. After that it drops off until we hit several thousand which would be correct because now we are into the swoopers zone. We lose a huge chunk of our people to landing accidents. You are entering the 'cocky zone' and you will be there for at least the next two years. I know this because I have been there myself. It's not just the size that has us concerned, it's the choice to go full-elliptical. Get a nice semi 150 and learn to fly the piss out of it then think about getting an elliptical.
And to address your concern, quality canopy coaching is ALWAYS available at no cost to you. You just need to seek out the really good ones that care and buy them a few beer to talk over. I'm not qualified to do this so I don't- I just recommend people to the ones who are.
Go ahead and try to prove eveyone wrong- you won't be the first. In the meantime, get your lines checked out.
Go to skydiveradio.com and listen to the Brian Germain interview and see what he thinks about downsizing too fast... I mean he literally wrote the book on HP canopy flight, has over 10k jumps, and designs parachutes. But if you think you know something he doesn't, by all means come back and let us know.
TaylorC 0
Anyways if any of you are at the canadian invasion in AZ in january you will see me there with my white/blue ribbed cobalt and if you would like to talk to me in person i would prefer that since a lot of shit doesn't come out properly on the internet.
marks 0
Quoteit's the choice to go full-elliptical.
I dont have any problem putting aff students under full elliptical canopies. Why is it because of an ellipse it is "dangerous"?
dbattman 0
Taylor- hope we don't come out sounding too hard, but we hate seeing people go too fast and get hurt. Get some good canopy coaching and evaluation before the unexpected happens.
Canuck
