Faicon9493 141 #1 November 12, 2005 I just got a replacement visor for my Oxygn A3. What is the trick to putting it on? It came with no instructions. Quote Share this post Link to post Share on other sites
klafollette 0 #2 November 13, 2005 Get yourself an allen wrench for the side plates. Make sure you've got a bowl or something to put the screws in. Pull off the side plates, the visor will come off. The 2 plastic ratchet assemblies can be a little tricky. Use a small screwdriver or butter knife to push in the latch that holds the ratchet in the square hole of the visor. I remove the ratchets and put on new visor, one at a time, so I don't confuse which is from each side. Reverse the process to assemble. Quote Share this post Link to post Share on other sites
RMURRAY 1 #3 November 13, 2005 QuoteI just got a replacement visor for my Oxygn A3. What is the trick to putting it on? It came with no instructions. take a good look at it before removing the pivot/ratchet pieces. keep the left and right separate, don't mix up. put them on the new visor the same... rm Quote Share this post Link to post Share on other sites
tdog 0 #4 November 15, 2005 The guy at Square 2 in Eloy gave me a great tidbit... Keep the plastic bag on the new lens... Just cut open both ends and slide it to center, exposing just the ends, so as you handle it, the bag keeps the finger prints off the lens and protects it until it is installed... Then, when installed, cut the bag off... Quote Share this post Link to post Share on other sites
