billvon 3,151
>Then why can a parachute while swooping or one that flies faster gain
> more altitude when coming into brakes/flaring quickly than a larger
> slower parachute?
Because it has more energy to turn into lift. Energy = 1/2MV^2, which means that if you double your speed, you have four times the energy. Small canopies have to fly faster to generate enough lift to keep you in the air, since all parachutes have to generate enough lift/drag to exactly balance your weight. With small canopies, you fly faster, so you have more energy to convert into lift at the end.
> slower parachute?
QuoteWith small canopies, you fly faster, so you have more energy to convert into lift at the end.
So lift is created by speed.
Cheers,
Travis
Canopies want to find an equilibrium. Smaller canopies do fly faster in order to produce the same lift as a bigger canopy.
Forgetting the difference between lift and drag and just taking both to be the "upward" force created by a canopy, it's easy to see that a tandem drogue creates the same "lift" as a tandem main. When the rate of descent is constant (terminal velocity), both the drogue, in freefall, and the main, under canopy, are pulling up at exactly the weight of the jumpers. They just happen to be going very different vertical speeds to achieve the same lift.
Swooping is a dynamic situation. Lift does increase when the swooper comes out of a dive. When a canopy accelerates upward (ie levels off from a dive or actually goes up), lift no longer equals weight.
Dave
