nicknitro71 0 #1 October 5, 2005 Modern Ram Air canopies have one of the following configurations as upper control lines (line 1 is the most outboard and consecutive numbers indicate 1/2 cell): A: 1, 3, 4, 5 (total of 2 cells) B: 1, 2, 3, 4 (total of 1 1/2 cells) C: 1, 2, 3, 5 (total of 2 cells) D: 1, 2, 4, 6 (total of 2 1/2 cells) E: 1, 2, 3, 4, 5 (total of 2 cells) F: 2, 3, 4, 5 (total of 2 cells) Also see the poor pic What do you think each configuration does in term of: 1. Opening 2. Toggle turn rate 3. Toggle pressure 4. Stall 5. FlareMemento Audere Semper 903 Quote Share this post Link to post Share on other sites
sid 1 #2 October 5, 2005 you're bored aren't you, Nick?Pete Draper, Just because my life plan is written on the back of a Hooter's Napkin, it's still a life plan.... right? Quote Share this post Link to post Share on other sites
nicknitro71 0 #3 October 5, 2005 To death!Memento Audere Semper 903 Quote Share this post Link to post Share on other sites
beezyshaw 0 #4 October 5, 2005 QuoteWhat do you think each configuration does in term of: 1. Opening 2. Toggle turn rate 3. Toggle pressure 4. Stall 5. Flare As someone who has been testing these configurations on canopies in development for many years, I can answer your question... To put it in basic terms (but keep in mind that certain canopies respond in slightly different ways), the more towards the center of the canopy you place the UCL, the stronger the flair, the firmer the opening, and the heavier the toggle pressure and slightly slower turn rate (usually). On the contrary, the more toward the outboard cells you place the UCL then you get lighter toggle pressure, reduced flair power, and snappier toggle turns. It is always a compromise of these issues when configuring the control lines on the trailing edge of the canopy. For instance, a canopy design that has an inherently strong flair can have the lines more outboard to give light toggle pressure without sacrificing good landings, etc., etc. ps I just saw the part about the stall; the more outboard the control lines, the deeper the control stroke it takes to stall the canopy, and of course visa versa. Quote Share this post Link to post Share on other sites
darkwing 5 #5 October 5, 2005 I agree with Beezy. That is what I found out when building canopies in the late 1970's, and while modern elipticals, etc., change things a bit, I don't think they change things much. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
