btvr 0 #1 September 29, 2005 Last weekend on two jumps my visor popped open in freefall. The first was when I flipped upside down and just brushed it off as a fluke because of the wind just catching it right. The second happened in a stable bellly to earth position. On the ground when I open the visor it doesn't seem to open any easier than it ever did. Has this happened to anyone? If so what did you do to remedy the problem? Thanks Quote Share this post Link to post Share on other sites
damion75 0 #2 September 29, 2005 On the first Oxygn I bought the visor flipped open and ripped off twice in four jumps - but I think the helmet mould was wrong because it never really looked like a good fit around the nose section between the visor and the helmet. What did I do? demanded a replacement! It was only two days old! And all credit to Square 2 I got one too - straight away. Never had a problem since. You see a few people with gaffer tape holding the visor down though. *************** Not one shred of evidence supports the theory that life is serious - look at the platypus. Quote Share this post Link to post Share on other sites
sdctlc 0 #3 September 29, 2005 Mine did a few times with it ripping off once. I evuentually just took it out and wear goggles unde rthe helmet now. Like it better that way anyhow.. Scott"He who Hesitates Shall Inherit the Earth!" Quote Share this post Link to post Share on other sites
jumper03 0 #4 September 29, 2005 QuoteMine did a few times with it ripping off once. I evuentually just took it out and wear goggles unde rthe helmet now. Like it better that way anyhow.. Scott ditto for me. Mine was actually kicked first, then never would stay shut after that.Scars remind us that the past is real Quote Share this post Link to post Share on other sites
Dionysus 0 #5 September 29, 2005 I have had mine open twice that I can remember. Once while I was bootie flying and the other was in the wind tunnel on my belly. I still have the same visor on my helmet and those two incidents seem to be isolated. I know that sometimes it is easy to not seat it all the way when closing it, particularly when you close it while wearing gloves. Quote Share this post Link to post Share on other sites
kallend 2,150 #6 September 29, 2005 QuoteLast weekend on two jumps my visor popped open in freefall. The first was when I flipped upside down and just brushed it off as a fluke because of the wind just catching it right. The second happened in a stable bellly to earth position. On the ground when I open the visor it doesn't seem to open any easier than it ever did. Has this happened to anyone? If so what did you do to remedy the problem? Thanks The visor is held in place by the spring loaded hinge pulling it rearwards into the recess in the helmet opening. In particular, the TOP of the visor needs to seat securely in the recess. The part around the nose really doesn't matter very much. Whenever I close mine, I run my fingers over the rubber seal at the top of the visor to ensure it is seated properly. Not had one problem since doing this (implying that i had a problem prior to doing this). Helmet has around 1000 jumps on it.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
diablopilot 2 #7 September 30, 2005 If the visor has been opened by force (such as you suggested in your first incident) the ratchet mechanisims are easily damaged. A new set will cost you aabout $8 to $10. Youll never get the lens really secure again till you replace them. Many tunnel flyers tape the lens shut anyway. Regualrs to the tunnel have switched to the Factory Diver, or better yet even the Bonehead Mamba.---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites
jamostar 0 #8 October 3, 2005 oxygens are shitty. get a not-so-shitty full-face with a quality closing system.Sig lines are so stupid. Quote Share this post Link to post Share on other sites
tso-d_chris 0 #9 October 3, 2005 QuoteRegualrs to the tunnel have switched to the Factory Diver, or better yet even the Bonehead Mamba. I like BH's low tech, highly effective locking mechanism. Quote Share this post Link to post Share on other sites
btvr 0 #10 October 3, 2005 Thanks for all the input. I replaced the visor yesterday and saw a difference on how the new one sat as compared to the old one. Did a jump and did back loops, front loops ect... it stayed closed. I guess it was time for a new one, the old was all scratched anyway. Can't justify another 300 bucks for a new one just yet! Thanks... Quote Share this post Link to post Share on other sites
jamostar 0 #11 October 3, 2005 every time you use it, the spring-based locking mechanism will get a little weaker.Sig lines are so stupid. Quote Share this post Link to post Share on other sites
kallend 2,150 #12 October 4, 2005 Quoteevery time you use it, the spring-based locking mechanism will get a little weaker. On what engineering principle do you base that statement?... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
Squeak 17 #13 October 4, 2005 Quoteevery time you use it, the spring-based locking mechanism will get a little weaker. Mine's fine so far with 200 jumps on it, not a lot I know. I am fussy about closing my visor and i always use 2 hands to do it (with gloves on), I then run my fingers over the top ridge of the visor and check it's seated correctly, so far no problems at all. Plus the Oxygn also allows me to wear my spec under it You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
hipgnosis 0 #14 October 4, 2005 So? Most mechanical devices will eventually fail. A3's are no different, which is why you have replacement parts that you can buy. Since you hear a lot of negatives about A3's, let me say that mine just went through a full season of 4 way/load organizing/big ways with no incident including *gasp* opening the visor on the ride to altitiude every time! Of course the lens is about due to be replaced but the locking mechanism is still sound. Diablo is right about having a different helmet for tunnel though - I use my old Factory Diver in there. Bill Quote Share this post Link to post Share on other sites
kallend 2,150 #15 October 4, 2005 QuoteQuoteevery time you use it, the spring-based locking mechanism will get a little weaker. Mine's fine so far with 200 jumps on it, not a lot I know. I am fussy about closing my visor and i always use 2 hands to do it (with gloves on), I then run my fingers over the top ridge of the visor and check it's seated correctly, so far no problems at all. Plus the Oxygn also allows me to wear my spec under it I have close to 1000 on mine, the springs are just fine and the visor stays closed.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
