I want mine to say "Wonderhog".
-Hunter S. Thompson
"No. Try not. Do... or do not. There is no try."
-Yoda
Quoteu can get a "wonderhog" stitched on your mudflap for example!
My V3...
The other side says, "micron"
----Disclaimer: I don't know shit about skydiving.----
QuoteThat should work, because you scream yooyoo to scare the invisible elephants away from the trees.
Have you seen any invisible elephant on the trees?
See? It is _working_ perfectly.
You're analogy is flawed. You're suggesting that potential problems with pin, bridle and pilot chute don't exist and that even if they did, a visual inspection by someone would not provide any means to address them. While such problems may be rare compared to the number of jumps made without issue, there are stories of problems with pin, bridle or pilot chute that are visually apparent. There are also incidents of fatalities and injuries caused by pilot chute in tow or premature deployment.
QuoteIf you can not jump without someone else blessing that is your private problem. I do every check before getting my gear on. I do ask for a pin check if I have a 2nd though. I keep my eyes open and tell if I see something usual. I can check you if you ask it so. Anyway: mind your own business.
Give me a break! I'll give you that my closing sentence may have been melodramatic. I don't have a problem if he wants to do all his own checks on his gear. I don't think it wise, but that's his decision. What I take issue with is the suggestion that real skydivers don't need pin checks and the implication that asking for a pin check is tantamount to admitting ignorance of your own gear.
QuoteYou're analogy is flawed. You're suggesting that potential problems with pin, bridle and pilot chute don't exist and that even if they did, a visual inspection by someone would not provide any means to address them. While such problems may be rare compared to the number of jumps made without issue, there are stories of problems with pin, bridle or pilot chute that are visually apparent. There are also incidents of fatalities and injuries caused by pilot chute in tow or premature deployment.
As I told I check those when I get my gear on. Anyway an elephant would kill you if it would jump on you from a tree.....
QuoteWhat I take issue with is the suggestion that real skydivers don't need pin checks and the implication that asking for a pin check is tantamount to admitting ignorance of your own gear.
Its nothing about real skydivers. If you want to run 3 rounds around the airplane, because it give you luck and soft opening I say go ahead. If you try to push me to do it than piss off.
I real skydiver can decide if a pin check is needed.
QuoteAs I told I check those when I get my gear on.
Great! I never suggested that you didn't. I was faulting your analogy. With invisible elephants, you're suggesting a problem which doesn't exist and with screaming yooyoo, you're suggesting a solution which presumably has no real effect and then go on to draw the obviously false conclusion that you avoided the invisible elephant because of such action. Unlike the invisible elephants, problems which can be detected by visual inspection of the rig do exist, and having such a visual inspection prior to jumping can allow the problem to be either corrected, or failing that, at least mitigated by not jumping. Therefore, as I stated earlier, your analogy is flawed.
QuoteIts nothing about real skydivers. If you want to run 3 rounds around the airplane, because it give you luck and soft opening I say go ahead. If you try to push me to do it than piss off.
You need to go back and read my posts in context. They were all replies to specific posts suggesting that there was something wrong with asking for a pin check because as a licensed skydiver, you should know how to check your own gear. I strongly disagree with this sentiment and feel that this sends the wrong message to student and novice skydivers. While you didn't say that, you did question my position. I have no intention of attempting to force you to do anything.
QuoteI want mine to say "Wonderhog".
Now you're talking .... with a LoPo reserve and a Pegasus main.
(.)Y(.)
Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome
if i send mine in too, we may get a discount!?
it's only cool to basejump VX's tough..
-Hunter S. Thompson
-Yoda
