LisaH 0 #1 May 20, 2009 Can the LED display be repaired? Last night it started just showing partial numbers and I can't read it. Poop.Be yourself! MooOOooOoo Quote Share this post Link to post Share on other sites
iambeav2 0 #2 May 20, 2009 QuoteCan the LED display be repaired? Last night it started just showing partial numbers and I can't read it. Poop. So you're saying it reads..."POOP" now?...it's not the fact that you don't appreciate what you have until it's gone...it's the fact that you don't appreciate what you have until someone appreciates it for you! Quote Share this post Link to post Share on other sites
normiss 893 #3 May 20, 2009 What's a microwave? What the hell could you possibly need one for anyway??? Quote Share this post Link to post Share on other sites
horwichg 0 #4 May 20, 2009 QuoteWhat's a microwave? It's a clock that occasionally cooks stuff Quote Share this post Link to post Share on other sites
LisaH 0 #5 May 20, 2009 I should have known better than to post a serious question here. Be yourself! MooOOooOoo Quote Share this post Link to post Share on other sites
ryoder 1,590 #6 May 20, 2009 Quote Can the LED display be repaired? Last night it started just showing partial numbers and I can't read it. Those are called fractions, honey."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
ryoder 1,590 #7 May 20, 2009 OK, seriously: Go googling for the make/model name/numbers. You may pull up links to mfgr service information. If that doesn't work, then just try looking at the mfgr website for any service info at all, on the product line. If you still haven't found anything, then try a local appliance repair shop."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
LisaH 0 #8 May 20, 2009 Thanks Be yourself! MooOOooOoo Quote Share this post Link to post Share on other sites
rlucus 0 #9 May 20, 2009 Yes they can fixed... if you don't have electrical experience I recommend you take it to a professional. More than likely it is a simple LCD plugged into the control board by a ribbon cable... if this is the case then anyone with basic micro electronics skills could replace it with the right part. (Which should also be cheap if it is available) Quote Share this post Link to post Share on other sites
Andy9o8 2 #10 May 20, 2009 Quotetry a local appliance repair shop. Quote Share this post Link to post Share on other sites
LisaH 0 #11 May 20, 2009 QuoteYes they can fixed... if you don't have electrical experience I recommend you take it to a professional. More than likely it is a simple LCD plugged into the control board by a ribbon cable... if this is the case then anyone with basic micro electronics skills could replace it with the right part. (Which should also be cheap if it is available) This was merely a quick question so I don't waste my time on looking into it. Buying a new one would probably be easier.Be yourself! MooOOooOoo Quote Share this post Link to post Share on other sites
LisaH 0 #12 May 20, 2009 Quote Quote try a local appliance repair shop. Be yourself! MooOOooOoo Quote Share this post Link to post Share on other sites
normiss 893 #13 May 20, 2009 I gave a serious answer. I couldn't tell you the last time I used a microwave. I cook all the time, quite good at it actually. No nuker for me thank you. I don't like the way they heat things...at all. Quote Share this post Link to post Share on other sites
rlucus 0 #14 May 20, 2009 I'm horrible about fixing things... usually end up costing more the first time around... but then I've learned something new and can do it better the next time. I can't tell you how many times I've taken something apart to fix one thing and ended up breaking something else inside it. Latest was my Ipod... broken LCD $20, broken clip on main board while replacing the LCD $65 Quote Share this post Link to post Share on other sites
madhatter 0 #15 May 20, 2009 My microwave's LED hasn't worked for 5+ years now. Press the clear button a few times, select the options & time required & press start. It's quite simple if you trust yourself to push the right buttons A VERY MERRY UNBIRTHDAY TO YOU!!! D.S # 125 Quote Share this post Link to post Share on other sites
d_squared431 0 #16 May 20, 2009 Here is a question.... Can i put my wet clothes in the microwave to dry them off and if so for how long and what setting.... TPM Sister#130ONTIG#1 I love vodka.I love vodka cause it rhymes with Tuaca~LisaH You having a clean thought is like billyvance having a clean post.iluvtofly Quote Share this post Link to post Share on other sites
iluvtofly 0 #17 May 20, 2009 Yes you can...but I'm not sure your boss will appreciate it. Quote Share this post Link to post Share on other sites
d_squared431 0 #18 May 20, 2009 Quote Yes you can...but I'm not sure your boss will appreciate it. boss doesnt come back until 2pm so i might be okay to strip down and nuck my scrubs...TPM Sister#130ONTIG#1 I love vodka.I love vodka cause it rhymes with Tuaca~LisaH You having a clean thought is like billyvance having a clean post.iluvtofly Quote Share this post Link to post Share on other sites
normiss 893 #19 May 20, 2009 Quote It's quite simple if you trust yourself to push the right buttons that's what SHE said... Quote Share this post Link to post Share on other sites
madhatter 0 #20 May 20, 2009 A VERY MERRY UNBIRTHDAY TO YOU!!! D.S # 125 Quote Share this post Link to post Share on other sites
bluepill 0 #21 May 20, 2009 Its only a partial Mal. Glue another clock to the top of it and your good to go for a few more years. BP Quote Share this post Link to post Share on other sites
