shall555 0 #1 August 24, 2005 I was just doing a bit of "window-shopping" and checking out canopies. On the Big Air Sportz canopy order forms, there's an odd limitation: QuoteInternal ribs may not be black, blackberry or navy. I didn't see a restriction like that on any other manufacturer's order form. Do these colors make the fabric weaker ? Or is it simply more difficult to construct with darker colors in those spots ? ( A query to Big Air Sportz has, so far, not been answered. ) shall Quote Share this post Link to post Share on other sites
PhreeZone 20 #2 August 24, 2005 It makes it much harder to sew the Airlocks on in correctly. PD does it on the Vengence, but Brian does not allow it on his canopies due to the issue of construction hassle. As it was explained to me you have to sew blind through an airlock, a rib and another airlock to put it on. Dark fabric means you are truely blind to the second airlock, but lighter fabrics mean you can get the outline of the fabric to make sure its lined up right.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
ryand96 0 #3 August 24, 2005 Quote It makes it much harder to sew the Airlocks on in correctly. PD does it on the Vengence, but Brian does not allow it on his canopies due to the issue of construction hassle. This doesn't really make sense. According to a conversation I had with Brian at SDC's Spring Expo, all of his canopy's are manufactured by PD anyway. Quote Share this post Link to post Share on other sites
masher 1 #4 August 24, 2005 I've also emailed Brian about this. Apparantly PD wished they had made that restriction...-- Arching is overrated - Marlies Quote Share this post Link to post Share on other sites
skydiverek 63 #5 August 24, 2005 QuoteAccording to a conversation I had with Brian at SDC's Spring Expo, all of his canopy's are manufactured by PD anyway. With the exception of "signature series", I think. Quote Share this post Link to post Share on other sites
ryand96 0 #6 August 24, 2005 It was my impression that "signature series" canopies are manufactured by PD and then Brian mods them somehow. Although, I just looked at Big Air Sportz website and couldn't find any info on "signature series" for some reason. Quote Share this post Link to post Share on other sites
AndyMan 7 #7 August 24, 2005 Quote It was my impression that "signature series" canopies are manufactured by PD and then Brian mods them somehow. No. "Signature" canopies are made by Brian himself. He prefers not to do make canopies in the summer, when he does most of his traveling. Most of his "Signature" canopies get made in the winter. _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
ryand96 0 #8 August 24, 2005 I just found this thread that discusses Brian's "Signature Series." http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=1622680 Quote The Signature Series is a version of the Samurai and Lotus with some product updates that PD is unable to produce at this time. I build them myself. I have added a cross-bracing reinforcing tape along the airlock panels, running from the "A" line attachment to the apex of the non-loaded ribs. This makes the wing stiffer, and flattens each cell to create a better wing shape. I also increased the contraction of the leading edge tapes on the top and bottom skins, which reduces the drag of the wing in flight as well as softening the openings. This also reduces the front riser pressure. I am now also offering the swoop line-set, which dives longer to allow the pilot to start the dive higher and gain more speed. I think this is where I got the impression that the "Signature Series" was still manufactured by PD and then modded by Brian. After giving the thread a second look, it specifically states that they are built by Brian. I stand corrected. Quote Share this post Link to post Share on other sites
totalbodypilot 0 #9 August 24, 2005 The ribs on my Lotus 95 are "black" and it was made by PD last summer. Its hard to see in this picture, but they are "Black". (except for the 3 white ones in the white pannel) Blue Skies, Black Ribs, Colon Berry www.ecfreefly.com Quote Share this post Link to post Share on other sites
bob.dino 1 #10 August 25, 2005 I can't speak for the Vengance, but everything else you say tallies with what Brian told me when I wanted dark ribs for my forthcoming Samurai. Quote Share this post Link to post Share on other sites
Squeak 17 #11 August 26, 2005 QuoteI can't speak for the Vengance, but everything else you say tallies with what Brian told me when I wanted dark ribs for my forthcoming Samurai. You bought a Sami, BiotchYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
bob.dino 1 #12 August 26, 2005 It's a 170. But you're welcome to play if you'd like. Quote Share this post Link to post Share on other sites
