grue 1 #1 August 3, 2005 My new rig will include a used Fusion 210 canopy as the main, which takes 800-1000' to open, according to the previous owner. If I'm in a situation where I don't wanna snivel for a year, e.g. a boogie *cough*EloyHolidayBoogie!*cough*, is there a way I can pack it to SAFELY accelerate the opening? I don't wanna get bitchslapped, but I don't wanna be in the saddle at 2,000' if I dump at 3k or something. On the other hand, I weigh 35lbs more than the previous owner, will that make it open faster unto itself?cavete terrae. Quote Share this post Link to post Share on other sites
GeordieSkydiver 0 #2 August 3, 2005 Pull a little higher, your extra weight will help too. Pack as recommended by the manufacturer until you get to know the canopy inside out... Safety first.Lee _______________________________ In a world full of people, only some want to fly, is that not crazy? http://www.ukskydiver.co.uk Quote Share this post Link to post Share on other sites
phoenixlpr 0 #3 August 3, 2005 Do you quarter the slider? You may use a _little_ rear risers on snivel. Quote Share this post Link to post Share on other sites
EricaH 0 #4 August 3, 2005 Every single canopy is different & has different opening characteristics. I've packed my Specter at least 20 different ways. I use to have 1000 - 1200' openings. then I had off heading, then I had slow turning, then I had one or the other end cell closed, then slowly spinning... on & on. What I've finally figured out: put the slider behind the nose (not between the cells but behind), quarter the other 3 sides normally. Let the nose hang straight (I do make a little effort to make the center cell about a quarter inch ahead of the others). Roll the tail loosely- I normally see the nose sticking out when S folding. Take extra special care to leave the lines straight & in place. My rubber bands are pretty lose, but the tighter ones are toward the locking stows. The canopy is in the bag straight & even. There is no can't. Only lack of knowledge or fear. Only you can fix your fear. PMS #227 (just like the TV show) Quote Share this post Link to post Share on other sites
mattjw916 2 #5 August 3, 2005 Before you go experimenting, just pack it "normally", i.e. whatever method you are comfortable with, and see what the results are first. Unless you are pulling at 2k all the time, a 800-1000 ft opening won't be a big deal. Besides, 3500 is the max deployment altitude during the Holiday Boogie at Eloy. I'd try to be as current as possible, and comfortable with your canopy, before the boogie so that you can land out or x-wind without soiling yourself. NSCR-2376, SCR-15080 Quote Share this post Link to post Share on other sites
skydiverton 0 #6 August 3, 2005 QuoteDo you quarter the slider? reply] Please do not do this. There are samples enough from skydivers ending in hospital for not resetting a killed slider or even packing the slider incorrect! ++++++++++++++++++++++++++++++++++++++++++++ Using your droque to gain stability is a bad habit, Especially when you are jumping a sport rig Quote Share this post Link to post Share on other sites rendezvous 0 #7 August 3, 2005 If you are trying to speed up the opening, talk to the manufacturer first. If they don't recommend it, DON'T try it. Delaying an opening is one thing, trying to speed it up can get out of hand and be very dangerous. Quote Share this post Link to post Share on other sites wmw999 2,593 #8 August 3, 2005 Try packing very, very neatly. You can watch a rigger pack a reserve, and see how the canopy is stowed. The neater it is, the less "stuff" that has to happen when it opens. Plus you get the added benefit of having a neat packjob. Don't milk your lines (i.e. don't use your hands to smooth them so it looks like spaghetti at the very end because all of the unevenness is concentrated in the last 12"). After you wrap the tail around your canopy, don't roll it too aggressively -- just enough to keep it under control. Make sure your slider is sized appropriately -- if it's oversized, then the canopy will open slower. People have been known to cut holes in the slider, but I'd suggest talking to the manufacturer before anything like that. I don't roll my nose or anything, and I generally fold the stablilizers back instead of forward. It helps to keep the lines centered (where you want them), and to give the nose plenty of room to catch air. 800-1000 feet is a long time. I don't see anything wrong with wanting an opening in less altitude than that. I pack for quick openings, too. These things work for me. I have not been having slammers (Diablo main)(knock on wood). Whenever you're trying things in packing, keep a couple of rules of experimentation in mind. 1. Check with an experienced jumper or rigger. Not the guy who makes 500 jumps a year but uses a packer, but the guy who packs all of his own openings, and has for years. Think about the mechanics of what you're doing, and talk it over. 2. Never try more than 1 different thing at a time. That way if you get something you don't like, you know what caused it. Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites phoenixlpr 0 #9 August 3, 2005 Please correct me! AFAK quarter the slider is the official/recomended way: put against the stops and put it equally between front, back and the sabilizers. Quote Share this post Link to post Share on other sites Kimblair13 0 #10 August 3, 2005 Just get rid of the slider...it'll open fast for sure! Joking of course. Your extra weight may make it open quicker, when I wear weights with my main I get slammed. Quote Share this post Link to post Share on other sites sunshine 2 #11 August 3, 2005 QuoteDo you quarter the slider? reply] Please do not do this. There are samples enough from skydivers ending in hospital for not resetting a killed slider or even packing the slider incorrect! What? Quartering the slider is what i do on every packjob and is whats in the packing manuals. I am curious as to what you do with a slider. ___________________________________________ meow I get a Mike hug! I get a Mike hug! Quote Share this post Link to post Share on other sites arlo 0 #12 August 4, 2005 QuotePlease do not do this. There are samples enough from skydivers ending in hospital for not resetting a killed slider or even packing the slider incorrect! hang on a sec. do you mean to say do not "COLLAPSE" the slider? if so, then it's a confusion of terminology. it sounds like you're telling him not to pull the drawstrings on the slider and 'collapse' it because people sometimes forget to return it to it's full position. "QUARTERING" the slider involves bringing the slider grommets up to the slider stops on the canopy and bringing each side of the slider between its respective line groups. for example: the left side of the slider would go between the left front and rear riser line groups. the leading edge of the slider would go between the left front and right front riser line groups. etc. PLEASE make sure you use the correct terminology regarding the slider because someone can be seriously injured. the slider is meant to work by slowing down the opening and it works well when packed properly. you're jumping a stiletto, you SHOULD be quartering your slider. that's what PD recommends...trust me on this one. i hope this is indeed the source of the confusion. please verify that it is. thanks, arlo Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
