RALFFERS 0 #1 July 29, 2009 Ok, so a couple of weeks ago I noticed that my blackerry curve wasn't charging via the wall outlet charger - you have to fiddle with it in order to connect it, & as soon as you move the cord in the slightest way it disconnects... Naturally, I thought either my phone or charger is broken - BUT - when I connect it to my computer via the USB cable it charges just fine you can fiddle with it all you want & it'll stay connected solid. So than I thought that just the charger was broken, as a result I bought a new one. To my surprise, however, I'm having the same problem; I also checked the phone on my mom's charger; yu have to play with it some, but it does connect & stay connected. How probable is it that my original wall charger broke & the replacement I just bought is also defective?... I mean, I can't figure out for the life of me why it connects & charges via a USB cable with no issue at all, but not the wall charger(s). Oh yeah, it also connects fine in the car. Any ideas?Dialogue/commentary between Divot, Twardo & myself - "from your first Oshkosh when the three of us were riding to or from one of Quote Share this post Link to post Share on other sites
BillyVance 35 #2 July 29, 2009 I had that problem with my first blackberry, a 7230 model. Not having the problem with my current one, a 8703e model. The problem I'm having with it right now is a bad track wheel (on the side), so it's about time for a new model. Been thinking about getting the Curve though."Mediocre people don't like high achievers, and high achievers don't like mediocre people." - SIX TIME National Champion coach Nick Saban Quote Share this post Link to post Share on other sites
LisaH 0 #3 July 29, 2009 Try another wall outlet. Maybe something is wrong with the one you are using.Be yourself! MooOOooOoo Quote Share this post Link to post Share on other sites
JoeQ.Public 0 #4 July 29, 2009 There is a short between the phone and the chair. Very soon, an honest person will not be able to sing the last 2 lines of our National Anthem:::Practice safe dining....use condiments Quote Share this post Link to post Share on other sites
billvon 3,119 #5 July 29, 2009 > I mean, I can't figure out for the life of me why it connects & charges via >a USB cable with no issue at all, but not the wall charger(s). Most likely they use different connectors (actually, same connector, different active contacts.) One contact is getting dirty/worn out. Quote Share this post Link to post Share on other sites
RALFFERS 0 #6 July 29, 2009 QuoteI had that problem with my first blackberry, a 7230 model. Not having the problem with my current one, a 8703e model. The problem I'm having with it right now is a bad track wheel (on the side), so it's about time for a new model. Been thinking about getting the Curve though.Billy, although I'm having issues now, I would still recommend a BB curve over anything on the market, It should be noted that I've had this phone for 11 months, & in that time it has been dropped quite a few times. I'd like to sit here & think that is not the cause of my problems, but I'd probably only be lying to myself. So, if you're thinking of upgrading, take a look at this: http://na.blackberry.com/eng/devices/blackberrycurve8900/Dialogue/commentary between Divot, Twardo & myself - "from your first Oshkosh when the three of us were riding to or from one of Quote Share this post Link to post Share on other sites
RALFFERS 0 #7 July 29, 2009 Quote Try another wall outlet. Maybe something is wrong with the one you are using. I did - made no difference. Thanks for the suggestion though. Dialogue/commentary between Divot, Twardo & myself - "from your first Oshkosh when the three of us were riding to or from one of Quote Share this post Link to post Share on other sites
RALFFERS 0 #8 July 29, 2009 Quote > I mean, I can't figure out for the life of me why it connects & charges via >a USB cable with no issue at all, but not the wall charger(s). Most likely they use different connectors (actually, same connector, different active contacts.) One contact is getting dirty/worn out. Hmmm, I had no idea that could be the case, would of never thought that 1 & the same input use different connectors. Thanks for your insight! Do you think a can of pressurized air would clean it adequately? Or is it just time to fork over the cash for a new phone? In my experience over the last few years I've come to the conclusion that cell phones, no matter how expensive are designed to last approximately 1 year...Dialogue/commentary between Divot, Twardo & myself - "from your first Oshkosh when the three of us were riding to or from one of Quote Share this post Link to post Share on other sites
shropshire 0 #9 July 29, 2009 Quote> I mean, I can't figure out for the life of me why it connects & charges via >a USB cable with no issue at all, but not the wall charger(s). Most likely they use different connectors (actually, same connector, different active contacts.) One contact is getting dirty/worn out. or could it be that the connectors are from different manufactures, so are made to different tolerances... one fits, the other, sort of, sometimes? (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
