Lostinspace
Reline after 120 jumps and 1 off DZ landing.
I own a Sabre2-150 with 120 jumps on it. The canopy was purchased used with 40 jumps on it. I had an off DZ landing, where I landed next to a tree. My canopy caught the tree and incurred damaged. The canopy is at PD for repair.
The work includes a reline.
Reline:
(Right side A/B lines are longer than the left side and the lines are showing stress)
The right side was 1 1/2" longer than the left.
How could the lines get out of trim so fast? Is it from the landing?
(I landed, feet on the ground. The lines were slack)
Reline:
Just wondering. When lines are longer than they should be must it be relined. Can you not just cut off the extra lenght?
"be honest with yourself. Why do I want to go smaller? It is not going to make my penis longer." ~Brian Germain, on downsizing
Spectra doesnt expand, its shrinks. Its the shorter ones that are off-spec. Shortening the longer ones will make them both off spec.
Remster
Reline:
you're making too many right hand turns. try to make the same amount of left hand turns as you do right on the new line set ;)
I promise not to TP Davis under canopy.. I promise not to TP Davis under canopy.. eat sushi, get smoochieTTK#1
