normiss
Harley Davidson V-Twins on "How It's Made"
Will they explain the difference between a shovelhead and knucklehead? Maybe if I watch it, I'll be able to remember. :S:$
I have 4 knuckleheads, so I can tell you!
This is a Knucklehead..(my son's 1947)the rocker boxes are shaped much like a balled up fist.
http://img.photobucket.com/albums/v400/onekick/pipes023.jpg
The Shovelhead picture it attached (i haven't owned one of them since 83) Notice the rocker boxes are shaped somewhat like a shovel!
Both motors work on identical pincipals, shovels hold oil in better, (do to knucklehead rocker covers being stamped out tin, and shovels being one solid cast aluminum part)
You totally skipped right over the Panhead!
You've had this lesson before li'l missy!
B|
Knucklehead http://www.custom-choppers-guide.com/knucklehead.html
Panhead http://www.custom-choppers-guide.com/panhead.html
Shovelhead http://www.custom-choppers-guide.com/shovelhead.html
Even better set of pics including flathead: http://auto.howstuffworks.com/harley-davidson-engines.htm/printable
"There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones.
