SixtySecRush 0 #1 June 12, 2005 Whats the difference between the two and which should you have it set at for solo and RW jumps Quote Share this post Link to post Share on other sites
sundevil777 102 #2 June 12, 2005 From L&B's FAQ page: Basically TAS means your speed relative to the ground and SAS means your speed relative to the air molecules in a fixed altitude of 4,000 ft. and at a fixed temperature. TAS will change if you jump (with the same body position) at two Drop Zones which have different elevations. SAS remains the same. ...so, it 'normalizes' you speed to a standard set of conditions, so that you can compare easily. edit - page 39 of this link tells more about it: http://www.l-and-b.dk/pdf/english_protrack.pdfPeople are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
