jumper03 0 #1 June 9, 2005 what should I expect in the oral test portion? Is it a set time limit? A set number of questions? Until the DPRE is satisfied? I'm guessing anything is on the table to be asked? Thanks for any info in advance!Scars remind us that the past is real Quote Share this post Link to post Share on other sites
IanHarrop 43 #2 June 9, 2005 Check this out... Quiz Practice http://genbiol.cbs.umn.edu/alicense/"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
Hooknswoop 19 #3 June 9, 2005 This should answer a lot of questions: http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/14c115fcae79293486256ea000572074/$FILE/8610.5J.pdf Derek Quote Share this post Link to post Share on other sites
sunshine 2 #4 June 9, 2005 I was terrified of the oral quiz. But if you know your stuff, the answers will come to you. I aced the oral portion. ___________________________________________ meow I get a Mike hug! I get a Mike hug! Quote Share this post Link to post Share on other sites
Hooknswoop 19 #5 June 9, 2005 I think he means the oral portion of the Senior Rigger Certificate test. Derek Quote Share this post Link to post Share on other sites
jumper03 0 #6 June 9, 2005 QuoteI think he means the oral portion of the Senior Rigger Certificate test. Derek yep! and Pookiebear rigging????? Scars remind us that the past is real Quote Share this post Link to post Share on other sites
bodypilot1 0 #7 June 10, 2005 QuoteQuoteI think he means the oral portion of the Senior Rigger Certificate test. Derek yep! Like Sunshine said, if you know your shit it will be easy. Be safe. Edwww.WestCoastWingsuits.com www.PrecisionSkydiving.com Quote Share this post Link to post Share on other sites
