Twoply 0 #1 February 26, 2010 I'm talking when washing the dishes. It seems like you should use it, but is it a waste? Quote Share this post Link to post Share on other sites
likestojump 3 #2 February 26, 2010 the enzymes in soap only activate above a certain temperature, so if you are using cold water you may as well forgo the soap. Quote Share this post Link to post Share on other sites
wolfriverjoe 1,523 #3 February 26, 2010 Well, it's easier on the hands, and it helps the soap foam, and it softens stuff up better. So, yes. At least I think so. And how much waste is it to use a couple galllons?"There are NO situations which do not call for a French Maid outfit." Lucky McSwervy "~ya don't GET old by being weak & stupid!" - Airtwardo Quote Share this post Link to post Share on other sites
IanHarrop 43 #4 February 26, 2010 Quote And how much waste is it to use a couple galllons? Remember in Botswana they probably have to burn dried dung to heat water Hopefully they have a good supply of cow dung and don't have to use their own "Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
LongWayToFall 0 #5 February 26, 2010 The special thing about soap, is that it allows water and oil to mix together. Usually they would remain separate. The extra temp, in my mind, thins the oil and makes it easier to mix with the water. So yeah, I would say hot water is best. Quote Share this post Link to post Share on other sites
quade 4 #6 February 26, 2010 QuoteI'm talking when washing the dishes. It seems like you should use it, but is it a waste? The chemistry happens faster with greater temperatures.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
pontiacgtp00 0 #7 February 26, 2010 If they're greasy...using cold water seems to solidify grease, making it harder to clean up. Hot water keeps it in a liquid state. I used to wash a couple hundred pizza pans a day and I always kept the water seering hot. Quote Share this post Link to post Share on other sites
