Hooknswoop 19
QuoteYou can still legally jump the rig as long as you do not exceed the weight and airspeed limitations on the lightest and slowest component.
You are missing the point. It isn't that the Reserve or the harness is rated to less weight. It is that the reserve produces more load force during opening than the harness is certified to.
How much weight under a PD-113R would produce a maximum peak force of 3,000 or less pounds during opening? No way to know, so de-rating doesn't fix the issue.
“The strength of the harness must always be equal to or greater than the maximum force generated by the canopy during certification tests."
"A PD-113R label shows the average peak force of 3639 pounds.
The Mirage is TSO’d under TSO-C23b, Low-Speed Category (3,000lbs.)."
Derek
Hooknswoop 19
QuoteHe definately isn't blowing you off
Never did get an answer.
That is exactly what he did.
Derek
I love you, Shannon and Jim.
POPS 9708 , SCR 14706
