skittles_of_SDC
32 bit applications, 64 bit OS
The only reason I want to be able to run 32 bit is because plug-ins for Lightwave are version dependent and most are written for the 32 bit version. However I want to get the 64 bit versions of Maya, Max, and Z-Brush. (all 3D apps) The computer will be 100 percent workstation. All other stuff will still be happening on my laptop. So not much worry about anything other than those 3 apps.
Edit: and maybe After Effects and Premiere Pro when I get to compositing.
True, to a certain degree, but you won't be able to use them to the full capabilities of the software because you are only using one core of the processor. What 64 bit app are you trying to use?
Psst .... I think he said the other way around:P
(.)Y(.)
Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome
What he's saying is I can run it but it wont run to the processor's full ability. Which I kinda knew. I just wanted to make sure I didn't need additional software to run 32 bit apps on a 64 bit system.
If Skittles knew what i was talking about that's all that was necessary
damn french people!:P
American's are such an ungrateful lot... they would still be a British colony without the French :P
http://people.csail.mit.edu/sfelshin/saintonge/frhist.html
"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy
Fellas I'm not busting all of the french peoples balls...just shropshire's... besides since he seems to know his stuff as well then IT people can give each other shit no matter what country they originate from...besides France and Norway have the best countryside and when ever I finally get my D license and learn how to fly a wingsuit I will be there one day.
Now lets switch it to Canadians suck instead...;)
Short answer: True :)
Sometimes.
Two years ago x86_64 Ubuntu Linux did not include 32 bit libraries so 32 bit programs didn't run.
Getting into an application environment, 64 bit applications are not always compatible with plugins for the 32 bit version (Firefox).
Yeah that's why I need to run a 32 bit version of Lightwave. All the good plugins are for the 32 bit version and a lot of them aren't available anymore and a lot of the ones that are don't have 64 bit updates.
It depends on the architecture of the system board. Most CPU/System board combinations these days I believe you can install a single DIMM, but I could be mistaken (I do very little with PCs these days work mostly on Unix systems).
Thomas Crowe, NRP
Nationally Registered Paramedic
Red Hat Linux Geek
