btuttle 0 #1 May 6, 2005 Greetings. I have only done one tandem jump, but am positive there will be many more in my future... As we were riding under the canopy, I couldn't help but wonder how strong the two thin nylon straps holding me were... Therefore, I would like to know if anyone can point to any basic "strength" statistics of the harnesses being used for skydiving. Although I guess they're strong enough, it would be comforting to know that the harness can support xxxx pounds, etc. I searched, but could not find any info... Thanks! Quote Share this post Link to post Share on other sites
Kris 0 #2 May 6, 2005 Here's an excellent post on the subject. I found it in less than 5 seconds using the search funtion on "Harness Strength". http://dropzone.com/cgi-bin/forum/gforum.cgi?post=924988Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
cvfd1399 0 #3 May 6, 2005 unless it had been damaged or just a random act of god your body would most likley break before the harness would. You have to remember that the "system" is only as strong as the weakest link. That being said most webbing is rated into the thousands of pounds. It is most likley that hardware would fail first some of it is rated around 500 pounds. Quote Share this post Link to post Share on other sites
Kris 0 #4 May 6, 2005 Quoteunless it had been damaged or just a random act of god your body would most likley break before the harness would. You have to remember that the "system" is only as strong as the weakest link. That being said most webbing is rated into the thousands of pounds. It is most likley that hardware would fail first some of it is rated around 500 pounds. The chest strap harness buckle is about 500, IIRC, but all other hardware will withstand substantially more.Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
btuttle 0 #5 May 6, 2005 I'm telling you, I searched! Obviously not very well! Thanks for the responses. I am not jumping this weekend, but I do get to try power-parachuting... Now I have to find out how strong those chute lines are... Quote Share this post Link to post Share on other sites billbooth 10 #6 May 7, 2005 The MS-70101 chest strap buckle is only "rated" at 500 lbs., but it goes to over 2,000 before failing. It is also the most slip resistant buckle ever invented...even when it is made out of stainless. The first thing that ought to break on a super hard opening is your main risers. However, as long as people insist on jumping "no-stretch" lines, there is no telling what's going to go first. Quote Share this post Link to post Share on other sites Zenister 0 #7 May 7, 2005 sure there is... you will.. ____________________________________ Those who fail to learn from the past are simply Doomed. Quote Share this post Link to post Share on other sites Kris 0 #8 May 7, 2005 Good info to know, Bill. Thanks!Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites riggerrob 643 #9 May 18, 2005 Typical harness webbings include: Type 7: 6,000 pounds Type 8: 4,000 pounds Type 13: 7,000 pounds Most harness buckles will hold 2,500 pounds, but when you consider the pulley effect on leg straps, that is still in the 5,000 pound range. Shoulder hooks on tandems are more like 5,500 pounds ..... The bottom line is that your body will fail long before the harness will. One reason that harnesses are over-built is so they will hold together after 20 years of hard jumping, dragging through sand, sun burn, etc. Quote Share this post Link to post Share on other sites propilot 0 #10 May 18, 2005 Im curious what you mean by "pully effect". One pully does not reduce load, it simply re directs it. Right? Thanks in advance Quote Share this post Link to post Share on other sites propilot 0 #11 May 18, 2005 QuoteThe MS-70101 chest strap buckle is only "rated" at 500 lbs., but it goes to over 2,000 before failing. It is also the most slip resistant buckle ever invented...even when it is made out of stainless. The first thing that ought to break on a super hard opening is your main risers. However, as long as people insist on jumping "no-stretch" lines, there is no telling what's going to go first. Bill, are the "no-stretch" lines (im assuming you are referring to Spectra?) stronger than mini risers? Quote Share this post Link to post Share on other sites skydiverek 63 #12 May 19, 2005 QuoteBill, are the "no-stretch" lines (im assuming you are referring to Spectra?) stronger than mini risers? Cobmined - yes. Quote Share this post Link to post Share on other sites billbooth 10 #13 May 19, 2005 One Type-17 mini-riser will break at about 3,500 lbs., when new. Spectra lines for parachutes come in several strengths, from 425 to 1,500 lbs. It is more common to break a single line (or a link) than a riser. I have never seen a situation where all the lines on a riser broke, and left the riser intact. What is important, is that the harness below the riser is stronger than the riser. The main riser is designed to be the "fusable link", which "protects" everything else, including your neck. An intact riser, with a broken main lift web (or neck), won't do you much good, will it? Quote Share this post Link to post Share on other sites propilot 0 #14 May 19, 2005 I seem to remember you saying that before...maybe now it will stick in my head :} Thanks Allen Quote Share this post Link to post Share on other sites riggerrob 643 #15 May 19, 2005 QuoteIm curious what you mean by "pully effect". One pully does not reduce load, it simply re directs it. Right? Thanks in advance >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> By "pulley effect" I meant that you have two leg straps (straight lower leg strap and upper leg strap with buckle) hanging below each hip junction, so each leg strap is only holding half the load. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
