skymama
Do you clean your cutaway cables every month?
After reading a post in the Incidents forum, I was just wondering if cleaning the cables is part of skydivers' routine maintinence of their rigs these days.
She is Da Man, and you better not mess with Da Man,
because she will lay some keepdown on you faster than, well, really fast. ~Billvon
I didn't want to get too far off topic in Incidents, so I didn't go into it there, but one of the comments in that post was about giving the rig to the rigger with the main attached.
When I do a reserve, one thing that I inspect is the 3ring release. The whole thing. Handle, cables channels and everything (yes the rings and attachment webbing too).
That means releasing it and checking that the long cable goes into the RSL side.
It also makes it easier to repack the reserve when the main is not in the way.
Skymamma, you're a mod - Shouldn't this be in General or Gear & Rigging??
Edit to clarify: By "long cable" I mean the one that releases 2nd.
"There are NO situations which do not call for a French Maid outfit." Lucky McSwervy
My riggah cleans and oils the cables every repack. (Its the former mechanic in him. He oils everything).
If my rigger puts oil on my cables then he aint gonna be my rigger for long, (silicone aint oil)
Gone fishing
Yeah, but now that is only twice a year. I believe you're supposed to clean them more than that.
Seems like it should be tied to the number of jumps you do, more than the calendar. I keep a can of ACE silicon spray in my skydiving tools, but I usually only do this on repacks. If I jumped several time a day, all year, I would do it more often, but on a good year, I only get about 100 jumps. I feel OK about only doing it twice a year, since I don't jump all that much.
The cable does get pretty dirty and oily. Some other good things about doing it are you can take the opportunity to flex your three-ring binder loops, you can get an idea if there's dirt or pebbles in the cable housing, and you can make sure that the ends of the cables are properly housed in the hard riser housing (sometimes they sneak off to the side).
Trapped on the surface of a sphere. XKCD
You got to them before me! Oil can not only damage things, it holds dirt...I seriously doubt any rigger woudl use oil!
This is not something you can assemble wrong; either your cables are correct or they are not, and if you put the wrong cables into the wrong housings, one side will have several feet of extra cable and the other will not even clear the housing - so you won't be able to assemble the rig anyway.
However, it is indeed a good idea to make sure your cables are trimmed correctly when you replace the cutaway handle.
Sure it is ... you can bypass the Collin's Lanyard.
"That looks dangerous." Leopold Stotch
