skybeergodd
HELLLLP!!!..Anyone an expert with Excel Documents
I am in desperate need of help. I have an Excel document and I need to merge two columns together. What I have now is a document with columns A, B,C,D,E,andF and I need to merge the information in columns C and D and end up with a document that is A,B,C,D and E.
Can anyone help me with this???
On the top right of the task bar...
Click on "HELP"
In the drop down, click on "Microsoft Excel Help"
(or just hit F1)
In the Assistance / Search for Window, search on "Merge the contents of multiple cells into one cell"... click the green arrow to the right to search
Click on "Merge or split cells or cell contents"
Under "What do you want to do"... click on "Merge the contents of multiple cells into one cell"
Read!
Good luck
OK...let me clarify, I have Excel 2007 and I do not want to lose or have to retype all the data....what I have are address' column C has the numerics and Column D has the street names...I want to merger those two columns into a single column C with numerics and street names together.....If anyone can do that please either let me know how for PM me here and I can send you the file so you can work your magic. I'm just getting incredibly frustrated trying this.:S
How big of a file are we talking about? I dont see any easy way to do it in excel, but if you really need it, I might be able to write something to make it work and just send me the file, Ill see what I can do.
ETA: Yeah, didnt look at Mikes link... that should work for you, if it doesnt, try using "=concatenate(x1," ",y1).
I guess Im just looking for shit to write a program for... [:/]
"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly
DPH -7, TDS 578, Muff 5153, SCR 14890
I'm an asshole, and I approve this message
Bored today, ski?
What gave it away?
yeah, that was a bit of a pain in the ass, but I got it to work, check your pm box
On a side note, I figured my Core2 Duo 2.4 GHz processor with 4gb ram would have been able to manipulate that data a little bit faster... It took me more time because the excel kept crapping out on me than it did to just fix it a different way.B|
A simpler way than concatenate is simply to go to a blank column and type:
=C1&D1
It will merge the info from the two columns into the new column. If you want a space between the two bit of info, try:
=C1&" "&D1
Or if you want a dash in between:
=C1&" - "&D1
The number "1" needs to be whatever row you are on.. Copy/paste-value the new column, delete C and D and insert your new info. If you get into trouble: CTRL+Z (undo!).
"There is no problem so bad you can't make it worse."
- Chris Hadfield
« Sors le martinet et flagelle toi indigne contrôleuse de gestion. »
- my boss
=C1&D1
=C1&" "&D1
=C1&" - "&D1
why would any guy want to do something the easy way if there is a hard way that looks more macho?? :ph34r::D
Give one city to the thugs so they can all live together. I vote for Chicago where they have strict gun laws.
=C1&D1
=C1&" "&D1
=C1&" - "&D1
Well, GEE, whoever would have thought that to do a concatenation you'd use the concatenation operator?:o
www.mrexcel.com/tip074.shtml
=C1&D1
=C1&" "&D1
=C1&" - "&D1
Yeah... but... but that's "hard", Nat! Most people don't want to RTFM!!!
:D
* slaps forehead *
You really have no idea what you're doing? Right?
Do what Nataly said for the first row and then copy / paste into the subsequent rows. Excel will fix it for you.
Or double-click on the bottom right-hand corner of the cell with the formula.. It will flow down the 4000 rows on its own.
Edit to say: of course the OP has no idea.. Hence the question. Not everyone has used Excel before..
- Chris Hadfield
- my boss
You hit the nail on the head....I really have no clue, all your computer talk might as well be in japanese. I have spent days hitting the help button, following commands ect. ect. and it's just never worked. There is always one small little detail thats left out or "doesn't apply in this particular situation" that screws everything up. computers are not an area of expertise for me. I mean I can write out directions on how to place a surgical airway and I can follow those direction without a problem, but those same directions would be meaningless to someone without a base knowledge of anatomy and general surgery.
Problem solved??
Heres what you need. (Try it first on a copy of your workbook)
Hit ALT + F11
Insert -> Module
Paste the following code:
Sub merge()
LastRow = Range("A" & Rows.Count).End(xlUp).Row
For a = 1 To LastRow Step 1
Range("C" & a).Value = Range("C" & a).Value & " " & Range("D" & a).Value
Next a
Columns(4).Delete
End Sub
Hit F5
Delete the code again (otherwise excel will say the workbook has macros bla bla bla...)
Close the Window (Microsoft Visual basic)
Now you should see the sheet with column C and D merged and columnd D deleted.
