adibuzz 0 #1 March 23, 2005 Hi Pls riggers i need some advice about STRONG tandems: 1. Is ok to use a main SET 400 with 10 yers old and 1200 jumps? 2. Harnes 8 yers old and 800 jumps Pls i need some sugestion etc. I`m original from Romania and heare is a lack of information about this problem. Thank`s Adrian Quote Share this post Link to post Share on other sites
skydiverton 0 #2 March 24, 2005 I would suggest to do an inspection by a certified rigger (for example US or european rigger) or send the rig to the manufacturer for inspection. If you life in romania (europe) you can consider a Next of Omega rig if you want new material (Out of these tho I think the Next is more durable) Although the $ is historic low. ++++++++++++++++++++++++++++++++++++++++++++ Using your droque to gain stability is a bad habit, Especially when you are jumping a sport rig Quote Share this post Link to post Share on other sites
riggerrob 643 #3 March 24, 2005 Your 10-year-old SET400 might still be airworthy, provided it has only been jumped on grass and has been recently re-lined. Hint: if the difference across the A-lines exceeds 3 inches, it needs new lines. Your 8-year-old harness needs a factory inspection. The last update involves double main closing loops. Hint: Wim de Vos operates a Strong Enterprises approved repair center in Austria. Quote Share this post Link to post Share on other sites
