Sangi 0 #1 October 3, 2010 ...happen if you had to cutaway while you had your chest strap loosened under main canopy? Would you fall out of your harness during reserve deployment?"Dream as you'll live forever, live as you'll die today." James Dean Quote Share this post Link to post Share on other sites
theonlyski 8 #2 October 3, 2010 ...happen if you did a search for that exact situation? You would find lots of different answers."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
wolfriverjoe 1,523 #3 October 3, 2010 Quote ...happen if you did a search for that exact situation? You would find lots of different answers. Most of them being that "You will die." Or "You're an idiot" for loosening it."There are NO situations which do not call for a French Maid outfit." Lucky McSwervy "~ya don't GET old by being weak & stupid!" - Airtwardo Quote Share this post Link to post Share on other sites
normiss 901 #4 October 3, 2010 Just don't loosen your chest strap until you have a good canopy??? Quote Share this post Link to post Share on other sites
Arvoitus 1 #5 October 3, 2010 QuoteJust don't loosen your chest strap until you have a good canopy??? You can create a malfunction after you've gotten your canopy flying. http://www.youtube.com/watch?v=QECtqCRNKxsYour rights end where my feelings begin. Quote Share this post Link to post Share on other sites
koppel 5 #6 October 3, 2010 I should be okay as I use a belly band ;)I like my canopy... ...it lets me down. Quote Share this post Link to post Share on other sites
normiss 901 #7 October 3, 2010 This is a whole other issue. I'm good with loosening my chest strap. Quote Share this post Link to post Share on other sites
billvon 3,121 #8 October 4, 2010 >Would you fall out of your harness during reserve deployment? Most likely not, provided it was not loosened to absurd lengths. But you may have a much harder time finding your reserve handle. Quote Share this post Link to post Share on other sites
JohnRich 4 #9 October 12, 2010 Quote...happen if you had to cutaway while you had your chest strap loosened under main canopy? Would you fall out of your harness during reserve deployment? Quickly cinch it back tight before cutting away. If you think that would take too much time, then don't loosen it in the first place, to a degree that you wouldn't be comfortable jumping. Or don't do maneuvers while it's loose that could cause the canopy to malfunction. Quote Share this post Link to post Share on other sites
format 1 #10 October 12, 2010 QuoteOr don't do maneuvers while it's loose that could cause the canopy to malfunction. Of course it's a valid point but there's a number of hairy situations I can think of. Good canopy, loosened chest strap, pretty low, out of the blue somebody hit your canopy. Say you must cut away, shock, no time - what do you do?What goes around, comes later. Quote Share this post Link to post Share on other sites
popsjumper 2 #11 October 13, 2010 Roll the dice? Brian Germaine touts this loosening the chest strap business even for youngsters. He should be able to answer this question.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
format 1 #12 October 13, 2010 Quote this loosening the chest strap business I love my slider while it's up - I hate it when it's down. I love my chest strap while deploying - i hate it while flying. and for the dices - I love them red&transparent, Vegas type, anti magneticWhat goes around, comes later. Quote Share this post Link to post Share on other sites
tjm 0 #13 October 14, 2010 When your chest strap is "loosened" it is still cinched in. When it is removed I would worry about this problem. -tjmIf you're not living on the edge; you're taking up too much room! Quote Share this post Link to post Share on other sites
liftedtitan 0 #14 October 16, 2010 QuoteRoll the dice? Brian Germaine touts this loosening the chest strap business even for youngsters. He should be able to answer this question. Ive read him post on this issue before (Brian Germain). He says it is nearly impossible to fall out of your harness with a loosened chest strap during cutaway/reserve deployment.Moriuntur omnes, sed non omnes vixerunt. Quote Share this post Link to post Share on other sites
popsjumper 2 #15 October 16, 2010 QuoteQuoteRoll the dice? Brian Germaine touts this loosening the chest strap business even for youngsters. He should be able to answer this question. Ive read him post on this issue before (Brian Germain). He says it is nearly impossible to fall out of your harness with a loosened chest strap during cutaway/reserve deployment. Maybe that was written before extremely loose became the fashion. BillV somewhat notes that in post #8.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
champu 1 #16 October 18, 2010 QuoteJust don't loosen your chest strap until you have a good canopy??? This is an important note when considering the order you perform your housekeeping once you get under canopy. I would not, for example, recommend loosening your chest strap prior to pulling your slider down behind your head as you're at an elevated risk of introducing a control system malfunction as you do that. Depending, as others have said, on just how long your chest strap is the greater danger is probably in locating and being able to pull your reserve handle as compared to falling out of your harness. Keep in mind that not only is your handle not going to be where you're used to it being but pulling it may also be funky. The main lift web that your reserve handle is attached to may have a lot more freedom of movement than you are expecting. Quote Share this post Link to post Share on other sites
