kansasskydiver
Lineover or not?
Shot a tandem video this weekend and on the deployment I swore up and down that there was something wrong with the canopy. The TM said that it jerked him a bit but that all was clear when it finished opening. We watched the video but it was hard to determine if in fact it was or not. I pulled it onto my computer and got a frame grab of it.
What's your opinion?
<--- See look, pink dolphins DO exist!
It is hard to tell, I wouldn't rule out a tension knot. Did you check to see if there were any burn marks on the canopy from a lineover?
None that we saw, it came out of it pretty quick if it was one. The video shows it opening normal then spinning with a final whip then everything's fine...
Just weird is all
Could have been a tension knot, the first serious tension knot I had under a tandem (resulted in a cutaway) looked a bit like a canopy/line entanglement until I noticed non of my lines were entangled with the canopy.
As a side note, there are many that would argue that there is no such thing as a true lineover on anything but a round canopy and that its truely a line/canopy entanglement when jumping a "square" canopy. However, that's something for another discussion on another thread.
it looks as though it's inverted, like it was packed with a step through...
Now that you mention it, it does look like maybe the tail got pushed into the lines and maybe caught temporarily before the slider came down fully allowing the lines to spread thus releasing the tail. Not really a step through but more like ??tension canopy??
My I who's also a TM says that lineovers happen quite a lot on tandem chutes, but they very often clear themselves. I saw this once or twice on tandem videos, the canopy looking like maybe a lineover but as soon as it's fully open, no problem.
One of our video guys usually films the tandem opening from ABOVE, making for an interesting video for experienced skydivers ;)
Maybe it had something to do with the EZ's though, can't remember seeing a video of a lineover slide off recently, on the Sigma or Icarus chutes, but there were some chops for line-overs though.
How come a line-over on a tandem chute is more fixable than a sport canopy? (At least that's what people tell me.)
ciel bleu,
Saskia
Might be a line-over. They sometimes clear during opening. It's also possible it was a extreme unsymmetric opening
Hey, a tandemcanopy has a lot more fabric that can cause troubles than a sportcanopy
What type of canopy is it. I have to agree EZ's produce quite some line-over's (when packed bad??) That is one of the reasons I like the BT80 tandemcanopy, far less malfunctions
Using your droque to gain stability is a bad habit,
Especially when you are jumping a sport rig
