AviationTD 0 #1 May 4, 2011 Anybody here an expert with air compressor? My 30 gallons compressor broke down. I would like to try and fix it before I decide to dump it. Quote Share this post Link to post Share on other sites
Anvilbrother 0 #2 May 4, 2011 More info about what it did when it died, and what its doing now. Have you checked the basics, getting power, checked manual or pressure switches with multimeter to ensure working, moter have a relay or cap that is not working, breaker triped, fuse blown. Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Quote Share this post Link to post Share on other sites
AviationTD 0 #3 May 5, 2011 Everything is working properly except for one thing. I noticed that the filtered intake is not working correctly. The air was pumping out instead. Quote Share this post Link to post Share on other sites
muff528 3 #4 May 5, 2011 Quote Everything is working properly except for one thing. I noticed that the filtered intake is not working correctly. The air was pumping out instead. Reed valve or check valve is broken. Quote Share this post Link to post Share on other sites
JohnRich 4 #6 May 5, 2011 Have you checked the compressor fluid reservoir level? Quote Share this post Link to post Share on other sites
AviationTD 0 #7 May 5, 2011 Best source to find replacement? Quote Share this post Link to post Share on other sites
theonlyski 8 #8 May 5, 2011 Hardware store? You should be able to atleast find an inline version that's threaded that you could install between the filter and the compression chamber."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
normiss 897 #9 May 5, 2011 Granger. and what brand is the compressor? Quote Share this post Link to post Share on other sites
warpedskydiver 0 #10 May 5, 2011 Or try McMaster Carr, way better prices and service. Quote Share this post Link to post Share on other sites
muff528 3 #11 May 5, 2011 QuoteBest source to find replacement? Just to clarify ...depending on the compressor and design there could be check valves of different types at various locations on the unit. I'm guessing the one associated with the air intake at the cylinder head is the problem. If you have a "reed" type check valve you need to inspect the reed (actually a thin metal leaf) to see if it has missing pieces. If it does you will need to be sure that the pieces are not inside the cylinder because it potentially can cause internal damage. Like others have said, you can get parts at various industrial supply houses. Or you may have to order the part from the manufacturer. Also, there are types of compressors other than the "cylinder" type (rotary, diaphragm, etc.) and even the various cylinder types can have different intake valve arrangements. Quote Share this post Link to post Share on other sites
AviationTD 0 #12 May 6, 2011 Coleman 30 gallon compressor I took it apart to see if reed value is damaged. How do you know if it is damaged? I can't tell at this moment because it looks fine to me. Quote Share this post Link to post Share on other sites
AviationTD 0 #13 May 6, 2011 Quote I'm guessing the one associated with the air intake at the cylinder head is the problem. If you have a "reed" type check valve you need to inspect the reed (actually a thin metal leaf) to see if it has missing pieces. You guessed right. I can see the metal leaf and it it appears to be intact. Nothing is broken. What other possible issues that can be associated with air being pumped out of air intake? Quote Share this post Link to post Share on other sites
muff528 3 #14 May 6, 2011 Quote Quote I'm guessing the one associated with the air intake at the cylinder head is the problem. If you have a "reed" type check valve you need to inspect the reed (actually a thin metal leaf) to see if it has missing pieces. You guessed right. I can see the metal leaf and it it appears to be intact. Nothing is broken. What other possible issues that can be associated with air being pumped out of air intake? Well, if nothing is broken then I guessed wrong! If the problem is still associated with the reed valve then some foreign object could be holding the reed open or maybe it slipped out of position. Bent, not seating against the intake hole, etc. pics? Quote Share this post Link to post Share on other sites
normiss 897 #15 May 6, 2011 or corroded from the moisture in the system. Quote Share this post Link to post Share on other sites
Andy9o8 2 #16 May 6, 2011 Have you checked for chewing gum in the works? Bet you haven't. Quote Share this post Link to post Share on other sites
muff528 3 #17 May 6, 2011 Quoteor corroded from the moisture in the system. Yeah ...or if the outlet check valve is corroded shut then the high pressure air could be forced back out of the intake. I would think that's unlikely, but possible, I suppose. Quote Share this post Link to post Share on other sites
muff528 3 #18 May 6, 2011 QuoteHave you checked for chewing gum in the works? Bet you haven't. ...or a big chunk of nanothermite. Quote Share this post Link to post Share on other sites
AviationTD 0 #19 May 9, 2011 I will post the pictures shortly but I think i discovered the source of the problem. the ring of the piston is literally gone. I noticed a large gap around the piston inside the chamber. I figured that is the reason why my compressor can't produce enough pressure for the reed value to function correctly. I have no idea how to replace the ring around piston or if it is a possible to replace the ring. Any advice here? Quote Share this post Link to post Share on other sites
boyfalldown 0 #20 May 10, 2011 http://www.harborfreight.com/air-tools/compressor-pumps/145-psi-3-hp-twin-cylinder-air-compressor-pump-67697.html Quote Share this post Link to post Share on other sites
akarunway 1 #21 May 10, 2011 Quote Anybody here an expert with air compressor? My 30 gallons compressor broke down. I would like to try and fix it before I decide to dump it. get off your cheap as and go buy another. time is moneyI hold it true, whate'er befall; I feel it, when I sorrow most; 'Tis better to have loved and lost Than never to have loved at all. Quote Share this post Link to post Share on other sites
JackC1 0 #22 May 10, 2011 QuoteI have no idea how to replace the ring around piston or if it is a possible to replace the ring. Any advice here? From those pictures, I'd say your compressor is well and truly copulated. It looks like it's got too hot and seized, possibly through lack of lubrication. Seriously, it's scrap. Quote Share this post Link to post Share on other sites
