timbarrett 0 #1 January 10, 2005 just moved to UK and had a repack done. I am used to seeing the lead seals used in the US and was surprised not to see one on my newly repacked reserve pin. Is the seal just a US thing and what is the common practice outside US? I will, of course, ask my rigger here but can't get thru right now so just indulging in a healthy dose of paranoia...."Work hard, play hard and don't whinge" Quote Share this post Link to post Share on other sites
yoink 321 #2 January 10, 2005 some riggers in the UK use 'em, and some don't. It's not required over here, but it is useful if you're taking your rig abroad... Quote Share this post Link to post Share on other sites
mr2mk1g 10 #3 January 10, 2005 Most (AFAIK) will use a seal on request if you're traveling back to the states. Otherwise it's by far the norm not to use them here. Other EU nations vary. Quote Share this post Link to post Share on other sites
Remster 30 #4 January 10, 2005 Thats right, all the UK riggers I used (2) were only happy to add a seal to our repacks. Makes traveling a lot easier.Remster Quote Share this post Link to post Share on other sites
timbarrett 0 #5 January 10, 2005 thks everyone"Work hard, play hard and don't whinge" Quote Share this post Link to post Share on other sites
riggerrob 644 #6 January 10, 2005 Most nations REQUIRE rigger seals on reserves. Brits are the "odd men out." Apparently - a long time ago - a silly British rigger sealed a reserve with nylon E-Thread (minimum 8.5 pound) instead of wimpy, cotton seal thread (max 3.5 pound) and the owner experienced a hard pull. Quote Share this post Link to post Share on other sites
usskydiver 0 #7 January 10, 2005 When I lived in England from 1995-1999, there was an advanced packer certificate. Advanced Packers were not riggers, and only riggers had seal presses. You might want to know if the person who packed your rig was an advanced packer or a rigger. Quote Share this post Link to post Share on other sites
Shivon 0 #8 January 12, 2005 They are not required here in Australia, but there has been a reasonable amount of debate over the last 12 months as to wether it should be mandated. One option that has (is) being looked at is paper seals. Quote Share this post Link to post Share on other sites
TrickyDicky 0 #9 January 12, 2005 QuoteWhen I lived in England from 1995-1999, there was an advanced packer certificate. Advanced Packers were not riggers, and only riggers had seal presses. You might want to know if the person who packed your rig was an advanced packer or a rigger. This afaik, is not the case. The advanced packer and rigger at my DZ would be happy to seal it, but they dont do it unless asked. MY rigger said she doesnt see the point in sealing, because in the event of getting your reserve out, and theres a problem, its most likely you'll lose the seal and then be unable to prove it was sealed in the first place. UK Skydiver for all your UK skydiving needs. Quote Share this post Link to post Share on other sites
proswooper 2 #10 January 13, 2005 Quote*** MY rigger said she doesnt see the point in sealing, because in the event of getting your reserve out, and theres a problem, its most likely you'll lose the seal and then be unable to prove it was sealed in the first place. the point of the seal is not to prove anything after a cut away but something to look at before you put your gear on to know that nothing has happened to the reserve since you last jumped your gear Quote Share this post Link to post Share on other sites
usskydiver 0 #11 January 14, 2005 QuoteQuoteWhen I lived in England from 1995-1999, there was an advanced packer certificate. Advanced Packers were not riggers, and only riggers had seal presses. You might want to know if the person who packed your rig was an advanced packer or a rigger. This afaik, is not the case. The advanced packer and rigger at my DZ would be happy to seal it, but they dont do it unless asked. MY rigger said she doesnt see the point in sealing, because in the event of getting your reserve out, and theres a problem, its most likely you'll lose the seal and then be unable to prove it was sealed in the first place. I haven't been to the UK in a couple of years but remember that (by law/direction) the seal is NOT connected to the ripcord (to add additional pull force) therefore, the seal would not be lost during the cutaway. As I recall, this was a rule made after a rig was improperly "sealed" w/E thread rather than "Sealing Thread." Correct me if I am wrong.... Tim T. Quote Share this post Link to post Share on other sites
ChrisClark 0 #12 January 14, 2005 Reserves in the UK can be sealed by Riggers, Advanced Packers and packers with an endorsed certificate. The sealing thread is not tied to the ripcord cable. This means that no force is required to break the seal. Quote Share this post Link to post Share on other sites
PhreeZone 20 #13 January 14, 2005 Does'nt that method introduce the possibility of a rigger tacking the freebag to the outside flap?Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
ChrisClark 0 #14 January 16, 2005 QuoteDoes'nt that method introduce the possibility of a rigger tacking the freebag to the outside flap? The sealing thread is tacked onto the outside layer of fabric next to the pin grommet which is set in stiffner plate. The rigger doesn't tack through the plate (pretty hard to do with small hand needle) so the tacking does't go anywhere near the reserve, freebag or other flaps. Quote Share this post Link to post Share on other sites
FineHavanas 0 #15 January 17, 2005 A few years ago I took my rig to the UK but I cound't jump it unless the seal was removed Quote Share this post Link to post Share on other sites
nitrochute 2 #16 January 17, 2005 years ago(1978) when i worked at para flite we had some people from the U.K. that we were training .i believe they were with the Red Devils or the R.A.F.,anyway, i was told that the reason they dont use seals over there is because years ago a lead seal came off a rig and found its way into the channels in the floor where the control cables go to an aircraft"s tail.the seal had weged itself in such a way that the cables jammed.(hence the control surfaces could not be moved) Quote Share this post Link to post Share on other sites
