midgetdivet
Replacing a PC kill line
The kill line should be replaced using the same material used by pilot chutes manufacturers. On this case you'll need to contact a rigger that has a bartack or zigzag machine. He/her will use a 725 spectra line.
Kill lines should be replaced after 400+ jumps or when it shows signs of shrinkage or damaged.
Kill lines can also affect the openings so have the line replaced is a good and cheap investment.
The cost (at least at our service department) is $10.00.
Blue Skies.
Augusto Marinho
Rigging Solutions
Gus Marinho
