JJEXP
Motorcycle helmets?
Anybody ever used or thought about using a motorcycle helmet for a full face? It would seem something designed to save you from hitting the concrete might work for our application. I would assume weight is the deciding factor here?
Yeah, they are pretty heavy, also where are you going to put your audible?
Skydiving helmets tend to be cut much higher on the back so you can bend your neck further back wheen you arch, most motor bike helmets I have seen would restrict this movement a bit.
