1969912 0 #1 November 11, 2012 http://www.youtube.com/watch?feature=player_embedded&v=v5aMT9MBfZI "Once we got to the point where twenty/something's needed a place on the corner that changed the oil in their cars we were doomed . . ." -NickDG Quote Share this post Link to post Share on other sites
CSpenceFLY 1 #2 November 11, 2012 My only question is What the hell did they think was going to happen? I saw that coming as soon as I saw the rigging. Quote Share this post Link to post Share on other sites
jakee 1,596 #3 November 11, 2012 QuoteMy only question is What the hell did they think was going to happen? I saw that coming as soon as I saw the rigging. Agreed. In what way was that ever going to work?Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
BIGUN 1,488 #4 November 11, 2012 Dumbass yanking the cable taught into the blades was almost a Darwin Award.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
CarpeDiem3 0 #5 November 11, 2012 QuoteIn what way was that ever going to work? Whoa! Well, if the cable had been longer so that it would have laid on the ground before the chopper got low enough to have it's blades hit it, that would have worked. Still would have been a dumb idea, but that could have done it. Quote Share this post Link to post Share on other sites
jakee 1,596 #6 November 11, 2012 QuoteQuoteIn what way was that ever going to work? Whoa! Well, if the cable had been longer so that it would have laid on the ground before the chopper got low enough to have it's blades hit it, that would have worked. May well have done... but it wasn't longer, and it wasn't suddenly going to stretch, either.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
petejones45 0 #7 November 12, 2012 QuoteMy only question is What the hell did they think was going to happen? I saw that coming as soon as I saw the rigging. It wasnt the rigging, the helicopter hit the cable. The way it was connected would not have an effect on why it crashed.Look out for the freefly team, Smelly Peppers. Once we get a couple years more experience we will be a force to be reckoned with in the near future! BLUES! Quote Share this post Link to post Share on other sites
CSpenceFLY 1 #8 November 12, 2012 QuoteQuoteMy only question is What the hell did they think was going to happen? I saw that coming as soon as I saw the rigging. It wasnt the rigging, the helicopter hit the cable. The way it was connected would not have an effect on why it crashed. I was referring to the length of the cable as being part of the rigging. Quote Share this post Link to post Share on other sites
akarunway 1 #9 November 12, 2012 Quote Quote My only question is What the hell did they think was going to happen? I saw that coming as soon as I saw the rigging. It wasnt the rigging, the helicopter hit the cable. The way it was connected would not have an effect on why it crashed. My quwstion is where is the spotter and signalman for the chopper? Alot of blame to go around. Drugs tests for everybody.I hold it true, whate'er befall; I feel it, when I sorrow most; 'Tis better to have loved and lost Than never to have loved at all. Quote Share this post Link to post Share on other sites
CSpenceFLY 1 #10 November 12, 2012 I'm betting he was the one person that told them this wasn't a good idea and was smart enough to be far enough a way not to be killed or show up on camera. Quote Share this post Link to post Share on other sites
JohnMitchell 16 #11 November 12, 2012 Quote Dumbass yanking the cable taught into the blades was almost a Darwin Award. Yep, I saw that too. Jeez, that guy just barely made it out of the way. I hope this video gets widely viewed by people working around helicopters. Quote Share this post Link to post Share on other sites
vitriol 0 #12 November 12, 2012 It's the first time I see this video in HD, thanks for posting the link! Unless the pilot doesn't have any experience with external charges, I can't believe the plan was to land with the sling still hooked to the machine and the structure. If he did have some experience or common sense, my guess would be that his hook wouldn't open, and that he could not release the cable. In that case you have to put some tension on the hook, either by lifting up and pulling on the sling (but then the cable can fall and get stuck on the structure) or by having someone pull on the sling. In any case he should not have put himself so close to the cable. Also, you are supposed to check that both your hook manual release and electric release work before doing any sling work. Quote Share this post Link to post Share on other sites
Divalent 155 #13 November 12, 2012 QuoteDumbass yanking the cable taught into the blades was almost a Darwin Award. Actually, the length of cable coming down from the tower gets sucked into the blades by the draft of the chopper itself. You can see right before it goes that it starts jostling a bit (which apparently spooked the camera guy enough that he high-tailed it), then all of a sudden it flies towards it. (it's quite clear if you step if frame by frame) Quote Share this post Link to post Share on other sites
BIGUN 1,488 #14 November 13, 2012 Perhaps you should watch it again.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
jtval 0 #15 November 13, 2012 QuotePerhaps you should watch it again. Or read the description on the video itself.My photos My Videos Quote Share this post Link to post Share on other sites
BIGUN 1,488 #16 November 13, 2012 OK, or that too. Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Divalent 155 #17 November 13, 2012 QuoteQuotePerhaps you should watch it again. Or read the description on the video itself. oops! My bad. I watched it again, and although the guy is mostly obscured behind the observer in the foreground, it does appear that he jumps up and grabs the cable, pulling it down at his location and causing the movement into the rotors. Quote Share this post Link to post Share on other sites
