Twoply 0 #1 November 15, 2012 I run into this quite a bit at work. I'll find some kind of arched header or circular wall that I have to shore up or whatever and need to contour plywood or steel to fit. I can obviously get the x and y dimension, but I dont know if there is a formula that can give me the radius or diameter of the arch with just these 2 dimensions assuming it's a portion of a circle. The y dimension could be as small as 2'-0" or as big as 50'-0" Quote Share this post Link to post Share on other sites
muff528 3 #2 November 15, 2012 I think this is what you're looking for. http://www.mathopenref.com/arcradius.html Quote Share this post Link to post Share on other sites
wetrock 0 #3 November 15, 2012 i would take a picture from a position as square to the arc as possible and measurements and play with them in Google sketchup that way i could get all the numbers i would need and be able to see if the curve holds close to the mathematical arc. I once had to order doors for some curved cabinetry and template and trial and error with a 6 foot compass was all i could figure out. This method adjust for the places where the arc was off have you tried googling radius of an arc? http://www.handymath.com/cgi-bin/rad2.cgi?submit=Entry Quote Share this post Link to post Share on other sites
base689 0 #4 November 15, 2012 Hello Twoply. If you have got physical access to said arc, and so, in addition to x and y, you can take also the measurement of s, where s is the length of the arc (see atteached pciture), beyond the web sites suggested by our friends, there is the following (approximate) formula allowing you to easily calculate the radius R: R = s / sqrt(24 · (1 - y/s))Stay safe out there Blue Skies and Soft Walls BASE #689 - base_689AT_NO_123_SPAMyahoo.com Quote Share this post Link to post Share on other sites
jcd11235 0 #5 November 15, 2012 If you're still looking for help, could you please upload an illustration in a more universally accessible format (no MS Paint here)?Math tutoring available. Only $6! per hour! First lesson: Factorials! Quote Share this post Link to post Share on other sites
quade 4 #6 November 15, 2012 Because you don't really want a section of a circle with a constant radius. You really want a parabola. At least I would. http://en.wikipedia.org/wiki/Parabola The advantage being the parabola is more structurally sound.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
headoverheels 334 #7 November 16, 2012 Quote The advantage being the parabola is more structurally sound. Why? Cycloids are sexy. Quote Share this post Link to post Share on other sites
maggyrider 10 #8 November 16, 2012 Given the lengths you have you can calculate the radius (double for diameter) of the circle as followed: r = (4x² + y²) / (8x) See the attachment for an explanation (sorry for the bad image quality).Nice words are not always true - and true words are not always nice. Quote Share this post Link to post Share on other sites
mr2mk1g 10 #9 November 16, 2012 http://www.youtube.com/watch?feature=player_embedded&v=HWmKdhSNXv8 Quote Share this post Link to post Share on other sites
FreeFallFiend 0 #10 November 16, 2012 Math Mike? Really? You're not fooling anyone...we know you can't count past potato Fiend I am about to take my last voyage, a great leap in the dark. - Thomas Hobbes. Quote Share this post Link to post Share on other sites
kallend 2,151 #11 November 16, 2012 QuoteBecause you don't really want a section of a circle with a constant radius. You really want a parabola. At least I would. http://en.wikipedia.org/wiki/Parabola The advantage being the parabola is more structurally sound. Not if he's fitting his reinforcing material to an existing CIRCULAR structure, as his post suggests.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
popsjumper 2 #12 November 17, 2012 My suggestion: String Theory will solve the problem. ...get a long string and....My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
zen_mtn_climber 0 #13 November 17, 2012 QuoteQuoteBecause you don't really want a section of a circle with a constant radius. You really want a parabola. At least I would. http://en.wikipedia.org/wiki/Parabola The advantage being the parabola is more structurally sound. Not if he's fitting his reinforcing material to an existing CIRCULAR structure, as his post suggests. Except that many arches only appear to be circular or parabolic when in reality they're some form of inverted catenary. A parabola is at least a close approximation to a catenary and easier to work with http://en.m.wikipedia.org/wiki/Catenary#section_2 ZMC Quote Share this post Link to post Share on other sites
kallend 2,151 #14 November 17, 2012 QuoteQuoteQuoteBecause you don't really want a section of a circle with a constant radius. You really want a parabola. At least I would. http://en.wikipedia.org/wiki/Parabola The advantage being the parabola is more structurally sound. Not if he's fitting his reinforcing material to an existing CIRCULAR structure, as his post suggests. Except that many arches only appear to be circular or parabolic when in reality they're some form of inverted catenary. A parabola is at least a close approximation to a catenary and easier to work with http://en.m.wikipedia.org/wiki/Catenary#section_2 ZMC He said (among other things) "...circular wall " (emphasis mine). As far as arches are concerned, Norman and Saxon arches are circular, Gothic consist of 2 circular arcs, Roman and Greek arches are circular or flattened circular. I doubt he's shoring up the gateway arch in St. Louis, which is a catenary.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
Andy9o8 2 #15 November 17, 2012 Quote Mathmatical problem Once you solve your mathmatical problem, we'll get cracking on your spelling. Quote Share this post Link to post Share on other sites
Twoply 0 #16 November 18, 2012 Ha! And I beat up ironworkers on their grammer! Good catch! Quote Share this post Link to post Share on other sites
oldwomanc6 60 #17 November 18, 2012 Grammar. lisa WSCR 594 FB 1023 CBDB 9 Quote Share this post Link to post Share on other sites
jrjny 0 #18 November 18, 2012 nice sig when you highlight it Quote Share this post Link to post Share on other sites
