overmyhead 0 #1 December 14, 2004 My rigger told that I have rubber bands on my reserve bag, he asked me if I want to take them off. He said it's better without rubber bands. any advise? Quote Share this post Link to post Share on other sites
mjosparky 4 #2 December 14, 2004 QuoteMy rigger told that I have rubber bands on my reserve bag, he asked me if I want to take them off. He said it's better without rubber bands. any advise? Read your owners manual and then have your rigger read it. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
usskydiver 0 #3 December 14, 2004 What rig??? Tim T. Team Paraclete Quote Share this post Link to post Share on other sites
teason 0 #4 December 14, 2004 I see that you have a Racer. If it's new, than it's probably the speed bag and has to use elastics. If it's a mod, then their shoud be two strips of 1" box weave sewn across the pouch where the lines were previously stoed. If the Mod was done correctly, your rigger will be undoing a modification that is recomended by the manufacturer. The next rigger who gets your gear may want to charge you to redo it. You need to ask your rigger if the mod was done correctly. You also might want to call Jumpshack and have them explain the virtues of rubber bands over safety stoes. You can also PM Sid. he works at Jumpshack. P.S. when your rigger tries to explain that elastics melt when they're used on brass grommets, ask him what the inside of the safety stoe made of.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
overmyhead 0 #5 December 14, 2004 Thanks Teason for you Info. I wil check with my rigger and I will let you know... QuoteP.S. when your rigger tries to explain that elastics melt when they're used on brass grommets, ask him what the inside of the safety stoe made of. What do you mean? Safety stows made out of rubber too? so why don't they melt? does javelin have the same rubber safe stow. Quote Share this post Link to post Share on other sites
sundevil777 102 #6 December 14, 2004 The inner portion (inside the sheathing) of the safety stow is basically rubber band. So, if the outer sheath was worn away, you have...People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
Hooknswoop 19 #7 December 14, 2004 Quote Safety stows made out of rubber too? so why don't they melt? with safety stows, the rubber material doesn't come in contact with the grommets. If the outer material is worn away, then the Safety stow is very old and needs to be replaced. Derek Quote Share this post Link to post Share on other sites
hookitt 1 #8 December 14, 2004 QuoteIf the outer material is worn away, then the Safety stow is very old and needs to be replaced. To add to that, it would likely never happen. The bands inside would break long before the sheathing would wear out.My grammar sometimes resembles that of magnetic refrigerator poetry... Ghetto Quote Share this post Link to post Share on other sites
rmsmith 1 #9 December 14, 2004 QuoteIf it's new, than it's probably the speed bag and has to use elastics. Here's a speed bag photo. Quote Share this post Link to post Share on other sites
teason 0 #10 December 14, 2004 Actually, I believe it is when the brass begins to oxidize that the rubber will break down. The oxidized brass can get in to the safety stoe, breaking down the rubber. The safety stoe is, however, quite robust and to be honest, I don't think faliure with proper storage and maintainance is likely. As for the Racer, replacing the e-bands at every repack should ensure elastic integrity. To answer a previous question, yes Javlin, like all US manufacturers (Jumpshack Excluded) uses safety stoes made from elastic bungee cord. It has been in use since it was introduced by Para-Flite in the early eighties. It is said to have more retentive force than conventional elastics and is said to be less likely to cause baglock. This is, however, up for debate as proper mil-spec elastics are designed to break to prevent baglock and the safety stoe will not. Safety stoe rubber can also degrade from heat (like the trunk of a car) and from oxidized brass. Because the stoe is sheathed, the degredation may go unnoticed. Ohhh ... this could start some good debateI would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
riggerrob 644 #11 December 14, 2004 First-generation Racers and last-generation Racers use rubber bands to close their free bags. Degradation of rubber bands only gets dangerous after 2 years in hot climates. We hope that you get your reserve repacked more often than that! Hee! Hee! Quote Share this post Link to post Share on other sites
RMURRAY 1 #12 December 14, 2004 I believe Jump Shack requires MIL spec rubber bands so I supply to my rigger at each repack to make sure... rm Quote Share this post Link to post Share on other sites
mjosparky 4 #13 December 14, 2004 Can someone tell me what defines a MIL-Spec rubber band? SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
Squeak 17 #14 December 15, 2004 QuoteFirst-generation Racers and last-generation Racers use rubber bands to close their free bags. Degradation of rubber bands only gets dangerous after 2 years in hot climates. We hope that you get your reserve repacked more often than that! Hee! Hee! Like Western AustraliaYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
bob.dino 1 #15 December 15, 2004 I can't find the current recommendation, but the specification until 1997 is here. Here's the associated notice of cancellation. Quote Share this post Link to post Share on other sites
mjosparky 4 #16 December 15, 2004 QuoteI can't find the current recommendation, but the specification until 1997 is here. Here's the associated notice of cancellation. Bob, Thank you for the information. You would not believe how long I have tried to find it. But leave it to Natick to re-invent the stow band. Where did you find it? SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
bob.dino 1 #17 December 15, 2004 Ten minutes with google. Thought process: 1. Search for "Mil spec rubber bands". 2. About the 7th result is dscc.dla.mil which appears to be a store of information on miltary specifications. Click it. 3. Not much there of interest, so try the "Document Index" link. 4. On the resultant page there's a link to the Document Automation and Production Service. 5. Type "RUBBER BAND" into the ASSIST search engine and see what comes up. Technology is wonderful, isn't it? Quote Share this post Link to post Share on other sites
mjosparky 4 #18 December 15, 2004 QuoteTen minutes with google. Thought process: 1. Search for "Mil spec rubber bands". 2. About the 7th result is dscc.dla.mil which appears to be a store of information on miltary specifications. Click it. 3. Not much there of interest, so try the "Document Index" link. 4. On the resultant page there's a link to the Document Automation and Production Service. 5. Type "RUBBER BAND" into the ASSIST search engine and see what comes up. Technology is wonderful, isn't it? At my age, technology sucks. I am doing good to turn the radio on. Thanks again, SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
RMURRAY 1 #19 December 15, 2004 QuoteCan someone tell me what defines a MIL-Spec rubber band? Sparky Rubber is a very broad term - I'm sure it just calls up a rubber type and some requirements. I don't really care much but someone could look it up. Here is the MIL spec number http://www.rubberbands.com/Parachute.htm rm Quote Share this post Link to post Share on other sites
Hooknswoop 19 #20 December 15, 2004 So does anyone have the current mil-spec for rubber bands? For rigger that re-pack Racers and use rubber bands on the free-bag, where do you get the rubber bands? How long can you store them? Derek Quote Share this post Link to post Share on other sites
mjosparky 4 #21 December 15, 2004 QuoteSo does anyone have the current mil-spec for rubber bands? For rigger that re-pack Racers and use rubber bands on the free-bag, where do you get the rubber bands? How long can you store them? Derek Derek, The latest Mil-Spec in Mil-R-1832-E but I can locate the specs. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
PhreeZone 20 #22 December 15, 2004 I found the Mil specs for storage of Rubber products here: http://www.reliasoft.org/mil_std/mil_hdbk_695d.pdf I can't find the Mil-spec on 1832-e. But here is the link for 1832-d that shows that it was canceled in 1997. http://assist.daps.dla.mil/docimages/0000/89/60/CAN1832.PD9 The part number for Mil-Spec bands is 11-1-4095, but I also can't find the revised specs.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
mjosparky 4 #23 December 15, 2004 QuoteI found the Mil specs for storage of Rubber products here: http://www.reliasoft.org/mil_std/mil_hdbk_695d.pdf I can't find the Mil-spec on 1832-e. But here is the link for 1832-d that shows that it was canceled in 1997. http://assist.daps.dla.mil/docimages/0000/89/60/CAN1832.PD9 The part number for Mil-Spec bands is 11-1-4095, but I also can't find the revised specs. I have the spec. sheet on 1832D courtesy of bob.dino. It is a 10 page document and covers Type I and Type II. I believe that 11-1-4095 is the drawing number for 1832E not the part number. Pree, you were right, that is the part number. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
RMURRAY 1 #24 December 15, 2004 QuoteSo does anyone have the current mil-spec for rubber bands? For rigger that re-pack Racers and use rubber bands on the free-bag, where do you get the rubber bands? How long can you store them? Derek without shopping for the best price - I bought them from JumpShack. Quote Share this post Link to post Share on other sites
Hooknswoop 19 #25 December 15, 2004 Quotewithout shopping for the best price - I bought them from JumpShack. Is that the only source? How do they differ from 'normal' rubber bands that you can get from Para Gear? I would really like to see the mil-spec on them and compare the para-gear rubber bands to the mil-spec requirement, see how they stack up. I'm glad I don't have to deal with this issue since I won't pack Racers. I'm just curious as to the differences. Derek Quote Share this post Link to post Share on other sites
