goofyjumper 0 #1 January 16, 2013 Count the number of significant figures in these two different numbers 52000 52.000 I have as 52000 = 2 significant figures I have as 52.000 = 5 significant figures (note the decimal) Am I wrong here?----------------- I love and Miss you so much Honey! Orfun #3 ~ Darla Quote Share this post Link to post Share on other sites
chutem 0 #2 January 16, 2013 Don't know squat about chem.... 52.000 would seem to have 2 significant figures as 52 is the same as 52.000. I have no idea if this might apply to your situation. Someone who does will be along shortly. Quote Share this post Link to post Share on other sites
missbrz 0 #3 January 16, 2013 It depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? Quote Share this post Link to post Share on other sites
beeman 0 #4 January 16, 2013 QuoteIt depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? I've also seen it where if you don't have the decimal and you want to show that it is 5 sig figs then you draw a bar over it. Then again, I've never seen that done in practice. At any rate I would prefer to write it as 5.2000 x 10^4. A lot less ambiguous.well...I was going skydiving anyway. let's go. Earn your pancakes. Quote Share this post Link to post Share on other sites
missbrz 0 #5 January 16, 2013 Quote Quote It depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? I've also seen it where if you don't have the decimal and you want to show that it is 5 sig figs then you draw a bar over it. Then again, I've never seen that done in practice. At any rate I would prefer to write it as 5.2000 x 10^4. A lot less ambiguous. I only see the bar in text books I agree with the scientific notation method being better. Quote Share this post Link to post Share on other sites
beeman 0 #6 January 16, 2013 Quote Quote Quote It depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? I've also seen it where if you don't have the decimal and you want to show that it is 5 sig figs then you draw a bar over it. Then again, I've never seen that done in practice. At any rate I would prefer to write it as 5.2000 x 10^4. A lot less ambiguous. I only see the bar in text books I agree with the scientific notation method being better. lol exactly :P. Never seen anyone use that in practice, even in research. If they really felt like even bothering with sig figs they did scientific notation.well...I was going skydiving anyway. let's go. Earn your pancakes. Quote Share this post Link to post Share on other sites
Squeak 17 #7 January 16, 2013 QuoteCount the number of significant figures in these two different numbers 52000 52.000 I have as 52000 = 2 significant figures I have as 52.000 = 5 significant figures (note the decimal) Am I wrong here? You are correct, where NO DP exists ENDING (trailing) Zeros are no significant, this is not to say that they are INsignificant.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
chutem 0 #8 January 16, 2013 QuoteIt depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? Cool I get to learn something. Is it 5 sig figs as the .000 shows acurracy to onethousandths? Quote Share this post Link to post Share on other sites
missbrz 0 #9 January 16, 2013 QuoteQuoteIt depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? Cool I get to learn something. Is it 5 sig figs as the .000 shows acurracy to onethousandths? it shows precision not accuracy. (they are different) but yes b/c it shows to the thousandths place Quote Share this post Link to post Share on other sites
chutem 0 #10 January 16, 2013 QuoteQuoteQuoteIt depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? I see, googled that one and saw it from the "shooters" prospective. (precision vs acc.) Thanks it shows precision not accuracy. (they are different) but yes b/c it shows to the thousandths place Quote Share this post Link to post Share on other sites wmw999 2,587 #11 January 16, 2013 What is the source of the numbers? There are places where periods, rather than commas, separate the zeros for thousands. Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites Squeak 17 #12 January 16, 2013 Quote What is the source of the numbers? There are places where periods, rather than commas, separate the zeros for thousands. Wendy P. Places called EUROPE You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites BIGUN 1,483 #13 January 16, 2013 http://www.ruf.rice.edu/~kekule/SignificantFigureRules1.pdfNobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites wmw999 2,587 #14 January 16, 2013 And South America But it's really, really weird-looking to most Americans Wendy P. There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites kallend 2,147 #15 January 16, 2013 QuoteIt depends on the precision of the 52000. it can have 2, 3, 4, or 5 significant figures. For instance if it is EXACTLY 52000 it is 5 sig figs. but if it is only precise to the 10's place it has 4 sig figs. you are correct on the 52.000 having 5 sig figs. make sense? 52000 is not the same as 52000. The trailing point indicates the precision.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites tan 0 #16 January 19, 2013 That's.. not entirely true right? If it's 52000.4967, 52000 is 5 sig. fig. Memories of math from a long time ago Quote Share this post Link to post Share on other sites goofyjumper 0 #17 January 19, 2013 Quotehttp://www.ruf.rice.edu/~kekule/SignificantFigureRules1.pdf Thanks for that!----------------- I love and Miss you so much Honey! Orfun #3 ~ Darla Quote Share this post Link to post Share on other sites BIGUN 1,483 #18 January 19, 2013 You're welcome.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites Coreece 190 #19 January 19, 2013 Quote52000 is not the same as 52000.. FIFYYour secrets are the true reflection of who you really are... Quote Share this post Link to post Share on other sites jakee 1,594 #20 January 19, 2013 QuoteThat's.. not entirely true right? If it's 52000.4967, 52000 is 5 sig. fig. But it's not 52000, it's 52000.4967Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
