ryoder 1,590 #1 March 12, 2013 http://news.yahoo.com/blogs/sideshow/video-radio-controlled-plane-flying-stratosphere-back-055227997.html"There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
JohnMitchell 16 #2 March 12, 2013 Video was out of service. Sounds like he hoisted a glider using a helium balloon. That would be some real rocket science to ascend a model aircraft that high on engine power. Quote Share this post Link to post Share on other sites
theonlyski 8 #3 March 12, 2013 http://www.youtube.com/watch?v=rpBnurznFio&feature=player_embedded Direct link"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
JohnMitchell 16 #4 March 12, 2013 Thanks. Interesting. I would have painted that thing bright orange, wouldn't you? I think they could have picked better weather, including winds aloft, for the mission, but that is cool. I've worked a number of high altitude balloon missions over the years. It's an interesting profile. Quote Share this post Link to post Share on other sites
Remster 30 #5 March 12, 2013 Quote Interesting. I would have painted that thing bright orange, wouldn't you? Unless you don't want any passer-by to pick it up and you have a high level of expectation to land it "next to your feet" Remster Quote Share this post Link to post Share on other sites
billvon 3,151 #6 March 12, 2013 >That would be some real rocket science to ascend a model aircraft that high on engine power. I've often thought about a hybrid rocket with a large booster made entirely out of propellant (skin and all.) The top of the rocket contains the glider and a tank of liquid oxygen. The rocket is launched and gets the glider to altitude, then continues its burn until the entire booster is consumed (or the remaining pieces are so small/light that they are not an issue for recovery.) The glider then returns. Quote Share this post Link to post Share on other sites
quade 4 #7 March 12, 2013 QuoteI've often thought about a hybrid rocket with a large booster made entirely out of propellant (skin and all.) How do you envision that working? Don't the walls of the rocket need to contain pressure so it can be forced out the back end nozzle? To me that implies a certain amount of robustness and resistance to being consumed by fire. If the propellant burned even microscopically different from one part of the wall to another, when it finally burned through wouldn't that send pressurized gasses out of it and make the rocket unstable?quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
kallend 2,188 #8 March 12, 2013 QuoteQuoteI've often thought about a hybrid rocket with a large booster made entirely out of propellant (skin and all.) How do you envision that working? Don't the walls of the rocket need to contain pressure so it can be forced out the back end nozzle? To me that implies a certain amount of robustness and resistance to being consumed by fire. If the propellant burned even microscopically different from one part of the wall to another, when it finally burned through wouldn't that send pressurized gasses out of it and make the rocket unstable? With a well designed propellant grain and careful manufacturing the propellant could be its own container, and "nozzle" could be an aerospike made of propellant. Just musing, I don't know what Bill had in mind.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
quade 4 #9 March 12, 2013 What kind of witchcraft is this? How the hell would you be able to keep the aerospike burning exactly correct so it maintains its shape? And how are you guiding this? Edited to add: http://www.youtube.com/watch?v=PBvfIpRsWpc Which is a solid rocket with an aerospike, but not the way I understood it as described by bill, which would be self consuming. The walls are still a structural element that contain the propellant and the aerospike is a separate and very solid component which is not consumed by use.quade - The World's Most Boring Skydiver Quote Share this post Link to post Share on other sites
kallend 2,188 #10 March 12, 2013 Quote What kind of witchcraft is this? How the hell would you be able to keep the aerospike burning exactly correct so it maintains its shape? And how are you guiding this? Edited to add: http://www.youtube.com/watch?v=PBvfIpRsWpc Which is a solid rocket with an aerospike, but not the way I understood it as described by bill, which would be self consuming. The walls are still a structural element that contain the propellant and the aerospike is a separate and very solid component which is not consumed by use. Gee, Paul, it's not exactly rocket science. (Maybe Bill will tell us what he had in mind)... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
riddler 0 #11 March 12, 2013 Linear aerospike engines were attempted on the X-33 project, to be named VentureStar, back in the late 90s as a shuttle replacement. The US Air Force evaluated the prototype and considered them an abject failure. It's one of many reasons we don't have a replacement for the shuttle today.Trapped on the surface of a sphere. XKCD Quote Share this post Link to post Share on other sites
billvon 3,151 #12 March 12, 2013 > Don't the walls of the rocket need to contain pressure so it can be forced out the back end nozzle? Yes. Carbon fiber, for example, is both very strong and very flammable in pure oxygen. A composite that used carbon fiber as the outer strength element in a matrix of propellant might work pretty well. >If the propellant burned even microscopically different from one part of the wall to >another, when it finally burned through wouldn't that send pressurized gasses out of it >and make the rocket unstable? Yes. At that point you throttle back to minimum oxidizer flow and just let the rest of the casing burn. At some point you'll lose structural integrity and the rest of the booster will effectively "fall off" but the goal would be to get most of the booster consumed. An alternative is to wait for burnthrough then max out the oxidizer flow and just blow the booster to bits. You go unstable in both cases but since you no longer have any significant thrust you just end up in an unusual attitude. Quote Share this post Link to post Share on other sites
