regulator 0 #1 April 29, 2013 The Breitling Emergency II. And yes its a watch that literally costs 15 grand. Guess its better to have one of these than a rolex that just looks good while you're dying from starvation. If you’re trapped on a deserted island, instead of spending months looking for the Pearl Station and figuring out the smoke monster you could just pull the antenna out of the Breitling Emergency II and call in a rescue party. This watch contains a small emergency transmitter that will notify authorities of your position as soon as you deploy an internal antenna, ensuring you won’t even get a chance to notify Desmond that it’s not Penny’s boat. The original Emergency watch, designed in the 1990s, sent a 121.5 MHz signal that could be detected by rescue craft within 100 miles of the watch. The new model also transmits at 406.04 MHz, a frequency that is now monitored by orbiting satellite. The watch can transmit for about 24 hours before the battery dies. The watch is huge – 51mm wide – and surprisingly thick. However, the fact they’ve been able to fit a solid transmitter and a nice quartz chrono into a package that could feasibly save your life is pretty cool. Breitling will also give you a new watch if you activate the transmitter in a real emergency situation. The piece will cost $15,000 when it’s released this year. The watch comes with a charger for the emergency module and the quartz movement is powered by a separate battery. It’s obviously a bit pricey so you may want to think twice before coughing up the cash. After all if, once you land on the island, you’re suddenly able to walk again and you get to hang around with Evangeline Lilly, you may just want to hang around for a while and see how things play out. Your call. For more on the Emergency, head over to A Blog To Watch’s hands on from Basel this year. http://techcrunch.com/2013/04/29/breitling-releases-the-emergency-ii-a-watch-that-can-save-you-if-youre-trapped-on-the-island/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+Techcrunch+%28TechCrunch%29 Quote Share this post Link to post Share on other sites
billvon 3,119 #2 April 29, 2013 You can get one from REI for about $300. Google "PLB." Quote Share this post Link to post Share on other sites
DiverMike 5 #3 April 29, 2013 Yes, but it would look silly on your wrist. http://www.rei.com/product/849914/mcmurdo-fastfind-220-personal-locator-beacon-with-gps For the same reason I jump off a perfectly good diving board. Quote Share this post Link to post Share on other sites
ryoder 1,590 #4 April 29, 2013 QuoteYes, but it would look silly on your wrist. http://www.rei.com/product/849914/mcmurdo-fastfind-220-personal-locator-beacon-with-gps No sillier than that gigantic wristwatch."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
Skyzilla 0 #5 April 29, 2013 If I'm trapped on a deserted island with Evangeline Lilly, I'm going to HIDE that watch. Quote Share this post Link to post Share on other sites
Stumpy 284 #6 April 29, 2013 I knew someone who had one of the previous version. Was useful if he ever needed a helicopter rescue from the golf course.Never try to eat more than you can lift Quote Share this post Link to post Share on other sites
billvon 3,119 #7 April 29, 2013 Right - but you can put it in your pocket. Less clunky that way. Quote Share this post Link to post Share on other sites
mx757 4 #8 April 29, 2013 recall Steve Fossett had one on when he crashed in Nevada... didn't do him much good... Quote Share this post Link to post Share on other sites
regulator 0 #9 April 30, 2013 Didn't he crash into a rock cliff? Quote Share this post Link to post Share on other sites
david3 0 #10 April 30, 2013 QuoteQuoteYes, but it would look silly on your wrist. http://www.rei.com/product/849914/mcmurdo-fastfind-220-personal-locator-beacon-with-gps No sillier than that gigantic wristwatch. Ironic that the watch that caused your plane crash by screwing with your weight & balance could then be used to save you. Quote Share this post Link to post Share on other sites
skydiver30960 0 #11 April 30, 2013 Quote Ironic that the watch that caused your plane crash by screwing with your weight & balance could then be used to save you. Until it drags you to the bottom of the ocean by your arm... Elvisio "negative buoyancy" rodriguez Quote Share this post Link to post Share on other sites
BIGUN 1,486 #12 April 30, 2013 And, while your showing off your cool new watch; go ahead and accidentally set the beacon off and see how much THAT costs. $100,000 FAA fine plus search-and-rescue costs for the false rescue.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
