Squeak 17 #1 November 25, 2013 The phone I now travel with is a 4G capable phone which operates on GSM/WCDMA/LTE does anyone know if it will work with your carriers there? specifically AT&T?You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
oldwomanc6 65 #2 November 25, 2013 TMobile Sucks! That is all!lisa WSCR 594 FB 1023 CBDB 9 Quote Share this post Link to post Share on other sites
Heatmiser 0 #3 November 25, 2013 Verizon's 4g network is cdma/lte/evdo, definitely not an expert, maybe that helps. What you say is reflective of your knowledge...HOW ya say it is reflective of your experience. Airtwardo Someone's going to be spanked! Hopefully, it will be me. Skymama Quote Share this post Link to post Share on other sites
theonlyski 8 #4 November 25, 2013 SqueakThe phone I now travel with is a 4G capable phone which operates on GSM/WCDMA/LTE does anyone know if it will work with your carriers there? specifically AT&T? So long as the frequencies line up, you should be good to go. http://en.wikipedia.org/wiki/List_of_LTE_networks"I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
FlyingRhenquest 1 #5 November 25, 2013 oldwomanc6TMobile Sucks! That is all! They all suck.I'm trying to teach myself how to set things on fire with my mind. Hey... is it hot in here? Quote Share this post Link to post Share on other sites
turtlespeed 226 #6 November 25, 2013 FlyingRhenquest***TMobile Sucks! That is all! They all suck. Then why do you use any of them?I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
labrys 0 #7 November 25, 2013 Quotedoes anyone know if it will work with your carriers there? specifically AT&T? Your current provider should know. Also, just knowing the model number of your phone can tell you if it probably won't (dual band), might (tri band) or probably will (quad band or more) You can look at the tech specs of your phone to see that info and what frequencies your phone will work on.Owned by Remi #? Quote Share this post Link to post Share on other sites
turtlespeed 226 #8 November 25, 2013 labrysQuotedoes anyone know if it will work with your carriers there? specifically AT&T? Your current provider should know. Also, just knowing the model number of your phone can tell you if it probably won't (dual band), might (tri band) or probably will (quad band or more) You can look at the tech specs of your phone to see that info and what frequencies your phone will work on. Why not just get a throw away phone? Put your service on hold/pause.I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
labrys 0 #9 November 25, 2013 QuoteWhy not just get a throw away phone? Put your service on hold/pause. Why not find out if the phone will work and if that's even necessary first?Owned by Remi #? Quote Share this post Link to post Share on other sites
turtlespeed 226 #10 November 25, 2013 labrysQuoteWhy not just get a throw away phone? Put your service on hold/pause. Why not find out if the phone will work and if that's even necessary first? It seems obvious that is being attempted, but if the process is so intensive and unproductive, just streamline it and make it easier.I'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
ryoder 1,590 #11 November 25, 2013 Check with the NSA; They will know."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
labrys 0 #12 November 25, 2013 Quote It seems obvious that is being attempted, but if the process is so intensive and unproductive, just streamline it and make it easier. Wow. I didn't realize that anyone would find the idea of simply looking at the tech specs for their phone "so intensive and unproductive". It takes about 30 seconds. At what point do you consider something like that so hard to do that you just throw money at it? Owned by Remi #? Quote Share this post Link to post Share on other sites
turtlespeed 226 #13 November 25, 2013 labrys Quote It seems obvious that is being attempted, but if the process is so intensive and unproductive, just streamline it and make it easier. Wow. I didn't realize that anyone would find the idea of simply looking at the tech specs for their phone "so intensive and unproductive". It takes about 30 seconds. At what point do you consider something like that so hard to do that you just throw money at it? When you have to post about itI'm not usually into the whole 3-way thing, but you got me a little excited with that. - Skymama BTR #1 / OTB^5 Official #2 / Hellfish #408 / VSCR #108/Tortuga/Orfun Quote Share this post Link to post Share on other sites
Squeak 17 #14 November 25, 2013 turtlespeed***QuoteWhy not just get a throw away phone? Put your service on hold/pause. Why not find out if the phone will work and if that's even necessary first? It seems obvious that is being attempted, but if the process is so intensive and unproductive, just streamline it and make it easier. Ill be out of my country for all of next year. (like in 2009) and I will be using my phone as a wifi hotspot for my tablet. so the throw aways like Tracfone are not much use to me.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
labrys 0 #15 November 26, 2013 Quoteso the throw aways like Tracfone are not much use to me. What phone do you have?Owned by Remi #? Quote Share this post Link to post Share on other sites
Squeak 17 #16 November 26, 2013 labrysQuoteso the throw aways like Tracfone are not much use to me. What phone do you have? ZTE T81 (it's Chinese built)You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
billvon 3,157 #17 November 26, 2013 >Wow. I didn't realize that anyone would find the idea of simply looking at the tech >specs for their phone "so intensive and unproductive". It takes about 30 seconds. Some people just do stuff. Some people try for about 5 seconds, give up, then spend 30 minutes posting on the web about how awful the thing is. Quote Share this post Link to post Share on other sites
Squeak 17 #18 November 26, 2013 billvon >Wow. I didn't realize that anyone would find the idea of simply looking at the tech >specs for their phone "so intensive and unproductive". It takes about 30 seconds. Some people just do stuff. Some people try for about 5 seconds, give up, then spend 30 minutes posting on the web about how awful the thing is. Some people dont know anything about phone and data networks, so the initialisms dont really mean anything to themHence the general enquiry on an open forum where it is known that there are quite a few folks with much more knowledge in such areas You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
labrys 0 #19 November 26, 2013 QuoteSome people dont know anything about phone and data networks, so the initialisms dont really mean anything to them Right on, Squeak. That wasn't about you... that was about someone suggesting that you just throw money away without taking the time to ask questions and learn new things...Owned by Remi #? Quote Share this post Link to post Share on other sites
labrys 0 #20 November 26, 2013 That one is on the "probably" list for AT&T GSM at least. You might need a new SIM card. Those are free or a few bucks. Contact AT&T over here and ask them.Owned by Remi #? Quote Share this post Link to post Share on other sites
labrys 0 #21 November 26, 2013 Quote Some people try for about 5 seconds, give up, then spend 30 minutes posting on the web about how awful the thing is. I see what you did there Owned by Remi #? Quote Share this post Link to post Share on other sites
Squeak 17 #22 November 26, 2013 labrys That one is on the "probably" list for AT&T GSM at least. You might need a new SIM card. Those are free or a few bucks. Contact AT&T over here and ask them. I absolutely plan on getting a local SIM card. Roaming data would send me to the poor house otherwiseYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
