yoink 321 #1 April 22, 2014 Dead simple, but I can't seem to figure it out. I'm trying to get an Excel macro to simply press Alt+PgDn 3 times in a row for me based on the position of the active cell so I can fill in some data, hit a shortcut and have it jump to the next set where I can fill in more data.... I'm assuming I need to use the SendKeys expression but can't get it working. Any VBA folks out there who could help with the code? Quote Share this post Link to post Share on other sites
DiverMike 5 #2 April 22, 2014 I made a command button that works: Quote Sub Button1_Click() ActiveWindow.LargeScroll ToRight:=1 ActiveWindow.LargeScroll ToRight:=1 ActiveWindow.LargeScroll ToRight:=1 End Sub For the same reason I jump off a perfectly good diving board. Quote Share this post Link to post Share on other sites
tan 0 #3 April 22, 2014 I'm no VBA expert, but you could use the default Record Macro in Excel to record these keystrokes and then extract the code. But because Alt+PgDn moves the "one screen", and each screen is a different size, the number of offset cells is different depending on the screen being used. Perhaps you could use this for a start: ActiveWindow.LargeScroll ToRight:=3 ActiveCell.Offset(0, 29).Select Change the "29" to however many cells fits into 3 screen widths for you. Hope it works for you? Quote Share this post Link to post Share on other sites
yoink 321 #4 April 22, 2014 uughh. You're both right. I'm an idiot. Thanks! Quote Share this post Link to post Share on other sites
theonlyski 8 #5 April 22, 2014 You're not paid by the hour, are you? "I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
yoink 321 #6 April 22, 2014 Sadly not... wish I was for this. *goes back to mindlessly entering data. Quote Share this post Link to post Share on other sites
