Calvin19 0 #1 June 11, 2015 How bad is bad? This is the back of my AC unit (Evap coil). The holes leaking water are the bottom of the evap coil section, beneath it is the heater section. The normal drain line is clear and working, but this is leaking out the back side. Anyone have any idea why this might be happening or how to fix it? All the HVAC guys I called are booked solid and I need to tile this room yesterday. https://www.facebook.com/Calvin19/videos/861014639631/?pnref=story Quote Share this post Link to post Share on other sites
billvon 3,114 #2 June 11, 2015 >Anyone have any idea why this might be happening or how to fix it? Junk in the tray; see if you can clean it out. Or the tray got tilted due to an inadvertent smack or something. Most systems either have two drain lines or a drain line plus an automatic shutoff to prevent this problem. One or the other isn't working - so see if you can locate either the float switch or the second drain to see what's up with it. Quote Share this post Link to post Share on other sites
Calvin19 0 #3 June 11, 2015 It has 2 drain lines, but they are two inches apart on the front (opposite side the holes in the video) I don't think there is any kind of float switch or mechanical part in the evap unit. And I don't think it can come apart/open up without a sawzall or a hatchet. I did vacuum out the drain line before this happened and I can see that maybe I dislodged a chunk of junk that dammed it up on the tray somewhere. shit. shit shit shit. Quote Share this post Link to post Share on other sites
oldwomanc6 60 #4 June 12, 2015 Do you have access to compressed air? Much more powerful than vacuuming. A couple of years after we built our house, we had a clog of the system from the construction dust. It clogged up the pump for the drain and did the same thing yours is doing. It turned out there were two areas that drained into the pump and drain tube. Blew that puppy out, and we were good to go.lisa WSCR 594 FB 1023 CBDB 9 Quote Share this post Link to post Share on other sites
BillyVance 35 #5 June 12, 2015 oldwomanc6 Blew that puppy out, and we were good to go. Ummm wait... what?!? Poor puppy! "Mediocre people don't like high achievers, and high achievers don't like mediocre people." - SIX TIME National Champion coach Nick Saban Quote Share this post Link to post Share on other sites
Calvin19 0 #6 June 12, 2015 oldwomanc6Do you have access to compressed air? Much more powerful than vacuuming. A couple of years after we built our house, we had a clog of the system from the construction dust. It clogged up the pump for the drain and did the same thing yours is doing. It turned out there were two areas that drained into the pump and drain tube. Blew that puppy out, and we were good to go. This is our working theory as well. It's this or a cracked tray. I like the fixable one better. A crack-pot team of the best experts in my area is stopping by after work tonight. We will know by perihelion. Quote Share this post Link to post Share on other sites
headoverheels 334 #7 June 12, 2015 Calvin19 A crack-pot team of the best experts in my area is stopping by after work tonight. We will know by perihelion. Hate to tell you, but that is next January. Quote Share this post Link to post Share on other sites
Calvin19 0 #8 June 12, 2015 headoverheels*** A crack-pot team of the best experts in my area is stopping by after work tonight. We will know by perihelion. Hate to tell you, but that is next January. on YOUR planet maybe. Quote Share this post Link to post Share on other sites
DiverMike 5 #9 June 12, 2015 Quoteon YOUR planet maybe. My planet also. In 2015, the Earth will reach its Aphelion at 19:41 (7:41 pm) UTC on July 6, 2015. For the same reason I jump off a perfectly good diving board. Quote Share this post Link to post Share on other sites
Calvin19 0 #10 June 14, 2015 DiverMikeQuoteon YOUR planet maybe. My planet also. In 2015, the Earth will reach its Aphelion at 19:41 (7:41 pm) UTC on July 6, 2015. I know, I know. I was paraphrasing one of my favorite science fiction novels. Mad points to anyone who can name it. Quote Share this post Link to post Share on other sites
