Amazon 7 #1 August 4, 2015 They are coming to get you..... http://www.digitaltrends.com/computing/mac-root-exploit-discovered-in-the-wild/ There’s a common misconception that Macs aren’t susceptible to any sort of malware or virus, but if evidence of exploits in the past hasn’t convinced you that isn’t the case, this news from Malwarebytes might. A recently discovered exploit, known by the file that makes it possible, DYLD_PRINT_TO_FILE, allows attackers to use the error reporting system within Mac OS X to create a file with root privileges. Once software has access to your root, it can manage every aspect of your system from installing malicious applications to locking you out entirely. Read more: http://www.digitaltrends.com/computing/mac-root-exploit-discovered-in-the-wild/#ixzz3hsnsVNdo Follow us: @digitaltrends on Twitter | digitaltrendsftw on Facebook Quote Share this post Link to post Share on other sites
BIGUN 1,486 #2 August 5, 2015 Just installed Win10. Loving it. During 8 & 8.1 I went all chromebook. Unfortunately, their docs, sheets and rest of the suite is less than stellar. My only question for MS is - why don't you version the WIN system in the year its deployed like you did with MS Office?Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Amazon 7 #3 August 6, 2015 BIGUNJust installed Win10. Loving it. During 8 & 8.1 I went all chromebook. Unfortunately, their docs, sheets and rest of the suite is less than stellar. My only question for MS is - why don't you version the WIN system in the year its deployed like you did with MS Office? They stopped doing that with 98.. then SE in 99.. then later Millenium.... They reserved the year versions for major releases for WINDOWS SERVER 2000 2003 2008 then SP1 SP2 R2 etc 2012 and so on.... Quote Share this post Link to post Share on other sites
BIGUN 1,486 #4 August 6, 2015 Thanks for the lesson, lady!!!Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
