Newbie
when do i change my CYPRES batteries?
If it says 10/04 then you have to replace the batteries somewhen in October, but not on a specific date!
Yes, the reserve has to be opened to change the batteries, but if the same rigger that packed your reserve the last time opens the reserve you don´t need a repack, he can just break HIS OWN seal, open the reserve container, put new batteries in your cypres and close the container again with a new seal. That is only if you are inbetween your reserve repack circle!
Saves you the money of a repack!
Otherwise the reserve has to be repacked after the seal was broken from a different rigger.
ROCK ON,.....HARD!
Proud European!!
