Squeak 17 #1 September 7, 2015 Im in the market for a down filled puffy jacket. we dont have a lot of call for them here in West OZ. so my local suypply is limited in variety. What are you all using? I need it to be light weight and packable into a small stuff sack.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
JerryBaumchen 1,486 #2 September 8, 2015 Hi Squeak, Quotedown filled puffy jacket These guys have their headquarters just up the street from me: http://www.columbia.com/on/demandware.store/Sites-Columbia_US-Site/en_US/Default-Start?mid=paidsearch&nid=Search%7CBranded%7CBrand%7CCore%7CUS&oid=Brand_Core+Brand_General_KW%28columbia+sportswear_e%29&did=columbia%20sportswear&eid=Google+Adwords+US&s_kwcid=AL!3937!3!63222497607!e!!g!!columbia%20sportswear&gclid=CPTx0ruU5scCFQeTfgoddswElg&ef_id=U1HmxAAABN8xwwYa:20150908001636:s They should have something that you might want. Jerry Baumchen Quote Share this post Link to post Share on other sites
wmw999 2,632 #3 September 8, 2015 What weight do you need? There are the thin, light ones used for layering, and then the thick ones that keep you VERY warm, but are overkill for anything but noticeable cold. Lots of brands; Columbia is good, as are LL Bean, The North Face, and many others. Patagonia has a line that's more expensive, but that guarantees humanely gathered feathers. If you're planning on using it in the US or somewhere else cold, I'd suggest trying them on, unless you're well within the average sizes. Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
aphid 0 #4 September 8, 2015 SqueakIm in the market for a down filled puffy jacket. we dont have a lot of call for them here in West OZ. so my local suypply is limited in variety. What are you all using? I need it to be light weight and packable into a small stuff sack. Nobody knows cold like Canadians. This companies products are renowned worldwide and offer a variety of fashions dependent on your anticipated use and environment. Because of it's global reputation, it is also one of the most abused by Asian knock-offs. You are forewarned... http://www.canada-goose.com/ca/en/our-history.html Quote Share this post Link to post Share on other sites
cengland 0 #5 September 8, 2015 What sort of temperature range are you needing it for?? Considering the potential costs and time for shipping to Australia you might consider a slightly oversized sheepskin coat with layers underneath with an Under Armour T shirt put on first to wick moisture away from the skin. With layering clothing you can add or remove layers to suit the outside temperature. From my personal experience growing up in Northern Ontario down filled jackets even with waterproofing don't fare well in wet weather. When I was quite active horseback riding and trail riding in the winter I layered cotton fleece long sleeved turtleneck over a cotton T shirt, a hooded zip up sweatshirt over the turtleneck and my sheepskin coat, I found this to be extremely effective in temperatures down to about - 20 degrees C. If there was rain or wet snow in the forecast I put on my Australian oilskin coat over the sheepskin coat. Just my 2 cents Quote Share this post Link to post Share on other sites
Squeak 17 #6 September 8, 2015 the primary use for the jacket will be for when Im hiking and camping overnight. The cold here in winter drops to 0C (low 30'sF). But it has to be able to pack down small enough to fit in a hiking pack with tent sleeping bag trangia food clothing etc.. Hence the need for down and not wool. I have pure wool thermals and a gortex outershell, so the jacket would be for layering and morning/evening when the temps drop significantly.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
cengland 0 #7 September 8, 2015 At those temperatures then I would say any of the online stores should be more than sufficient. Quote Share this post Link to post Share on other sites
vitriol 0 #8 September 8, 2015 Patagonia Men's Down Sweater Hoody. 800 fill down. Packs really small, lighter than a sweater, warm and looks good. Patagonia is a great company too. If it gets really cold just wear it with a shell on top. It's thin enough for that. I bought it for the evenings while trekking but I use it all the time now: traveling, trekking, working, in town! Quote Share this post Link to post Share on other sites
wmw999 2,632 #9 September 8, 2015 I use a down shirt for that same purpose. It's like a very thin down jacket; packs to nothing, and layers well. I bought based on weight and fit; lots of companies make them. I found it to be too warm for sleeping in at even 38F; I took it off and just used the underwear. Knut the down booties keep my cold feet warm Wendy P. There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
monkycndo 0 #10 September 8, 2015 I say Patagucci as well. Lifetime warranty.50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
Squeak 17 #11 September 8, 2015 ive got it norrowed down to a couple of jackets. Problem is that I dont have acceess to them here to try them on so has anyone got experience with fit and durability of these jackets? http://www.columbia.com/mens-compactor-down-jacket-1565981.html?cgid=men-jacketsVests-insulated&dwvar_1565981_variationColor=010#pg=2&start=29 http://www.cotswoldoutdoor.com/au/columbia-mens-flash-forward-down-hooded-jacket-a1212918 http://www.rei.com/product/886239/mountain-hardwear-ratio-down-jacket-mens-2014-closeout http://www.sierradesigns.com/product/dridown-sweater oh I have a 41-42 inch chest so it would look like Large is my size but I dont know how they fit. (big small tight etc...) ThanksYou are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
riggerrob 644 #12 September 8, 2015 Definitely buy a hoodie because an once of insulation on your head is worth a pound anywhere else. Try to think of your body as a chimney with all the heat escaping from your head and neck. Also look for a snug-fitting collar to keep warm blood flowing towards your head. Oh! And and about all those quest short jackets that leave your butt hanging out in the breeze ... great for fashion and you butt will remain small with all the shivering you do. For cold weather, I only buy thigh-length jackets. Even a single-layer down jacket (long enough to cover your butt) will reduce shivering in the morning. IOW Waist-length winter jackets only keep you warm when paired with bib overalls (high top pants). Quote Share this post Link to post Share on other sites
Phil1111 1,248 #13 September 9, 2015 Squeakive got it norrowed down to a couple of jackets. Problem is that I dont have acceess to them here to try them on so has anyone got experience with fit and durability of these jackets? http://www.columbia.com/mens-compactor-down-jacket-1565981.html?cgid=men-jacketsVests-insulated&dwvar_1565981_variationColor=010#pg=2&start=29 http://www.cotswoldoutdoor.com/au/columbia-mens-flash-forward-down-hooded-jacket-a1212918 http://www.rei.com/product/886239/mountain-hardwear-ratio-down-jacket-mens-2014-closeout http://www.sierradesigns.com/product/dridown-sweater oh I have a 41-42 inch chest so it would look like Large is my size but I dont know how they fit. (big small tight etc...) Thanks I'd go for the REI as they all use sewn through construction. It would have the most loft. Nothing wrong with sewn through for your purpose but the loft on a couple of these is minimal. I'd go with a fleece tuque ( http://www.cbc.ca/news/canada/edmonton/hey-hosers-what-do-you-call-that-cap-on-your-head-1.2455217 ). A jacket like that with a fleece tuque and fleece gloves will cover allot. Quote Share this post Link to post Share on other sites
stayhigh 2 #14 September 9, 2015 another vote for Patagucci. Patagucci is the new North Face.Bernie Sanders for President 2016 Quote Share this post Link to post Share on other sites
Squeak 17 #15 September 9, 2015 opted for the Colombia, Flash forward. light packable with a hood, good price landed.You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #16 September 13, 2015 SqueakIm in the market for a down filled puffy jacket. we dont have a lot of call for them here in West OZ. so my local suypply is limited in variety. What are you all using? I need it to be light weight and packable into a small stuff sack. North Face. Has it's own stuff-sack in the collar. VERY warm Quote Share this post Link to post Share on other sites
