Cappio 0 #1 September 11, 2004 I have a Skytronic Pro and the display reads "LLLL" when I turn it on. Anyone know what this means? The batteries are fresh. Instruction manual does not mention it. The Parasport Italia website has no information on this for Skytronic Pros. It does mention that this display on an FX means that the audible needs to rezero itself to ground level and gives instructions. But this is only for the FX. Does this mean the same thing on a Pro? If so then what? Cycling on and off does not help either. Thaks for your help. Quote Share this post Link to post Share on other sites
labrys 0 #2 September 11, 2004 The instruction manual doesn't explain how to reset the ground reference?Owned by Remi #? Quote Share this post Link to post Share on other sites
darkwing 5 #3 September 12, 2004 Maybe you are holding it upside down and it says "7777"? (That's really just a joke. I have nothing useful to suggest) -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
gerrcoin 0 #4 September 12, 2004 QuoteI have a Skytronic Pro and the display reads "LLLL" when I turn it on. Anyone know what this means?From: http://jumpvideo.com/pa_skytron_faq.htmlLLLL INDICATION You might get this indication when you go on an extended commercial flight or travel to another location with a different altitude. The unit needs to be manually calibrated: go to programming mode (press and hold MODE and SET) with both buttons depressed, the screen will begin blinking; press the MODE and SET buttons again and you should hear a beep -- you are now re-calibrated. This applies to the FX but I would imagine that the advice is also good for the PRO.QuoteMaybe you are holding it upside down and it says "7777"? (That's really just a joke. I have nothing useful to suggest)Like the guy who went to the autoparts store and asked for a 710 cap for his car engine. Quote Share this post Link to post Share on other sites
