jake330 0 #1 August 27, 2004 the color (orange) on some parts of my rig is fading and I want to touch it up. is there a specific type of dye that works best, and what should I avoid? or is this even a good idea? Quote Share this post Link to post Share on other sites
Fast 0 #2 August 27, 2004 There are threads on this but it comes down to: Don't do it. The RIG is TSO'd and its probally a major modification. Its nearly the same as taking a permenant marker to it. Most riggers wont touch it after you do it, etc. Search about this. There have been lots of posts.~D Where troubles melt like lemon drops Away above the chimney tops That's where you'll find me. Swooping is taking one last poke at the bear before escaping it's cave - davelepka Quote Share this post Link to post Share on other sites
cvfd1399 0 #3 August 27, 2004 would the manufactor re-die it? Quote Share this post Link to post Share on other sites
masterrig 1 #4 August 27, 2004 You might try calling the manufacturer of your container and tell them what you have. They can more than likely, replace the colors for mid-flap stripes or pop-top colors, etc. Dying a parachute harness-container is bad ju-ju, unless, you really, really know what you are doing and the type dye and all that is involved. It's best to telephone the manufacturer, they are real quick to help. Good luck. Chuck Quote Share this post Link to post Share on other sites
GravityGirl 0 #5 August 27, 2004 Which panels are you talking about? It makes a big difference. There are other options to "Dyeing". Such as panel replacement or painting. But it is VERY much depending on which panels you are talking about. ~~~~~~~~~~~~~~~~~ Peace and Blue Skies! Bonnie ==>Gravity Gear! Quote Share this post Link to post Share on other sites
jake330 0 #6 August 27, 2004 the flaps in question are the main pin flap, a couple of panels on the reserve flap, and the mud flaps. I've attached a picture of what the rig mostly looks like... Quote Share this post Link to post Share on other sites
RMURRAY 1 #7 August 28, 2004 jump it as is - it only shows the rig has been around for a while - nothing wrong with that. rm Quote Share this post Link to post Share on other sites
freeflysurf 0 #8 August 29, 2004 It looks great. You should be VERY happy with it Quote Share this post Link to post Share on other sites
riggerrob 644 #9 August 29, 2004 Mirage pin covers are easy to replace, but I will guarantee you that you will never exactly match the original colour. Fabric dying is a complex process, best done on full bolts of fabric. Nylon is easiest to dye before the fibers are extruded. Any dying method applied after nylon is extruded and woven will be less than "fast." Far wiser to just wash the rig and settle for the "experienced" look. Quote Share this post Link to post Share on other sites
